i use redline mt 90 gear oil.... no smell and works very well......
could be clutch smell as above post...
could be the rubber boot around the gear shift split.. this will weap oil onto the top of the gearbox and smell a bit..
hope this helps...
jezzerrr, had the same problem with my 33 GTR when I first bought it. I would smell gearbox oil fumes whilst driving. The problem was a split in the small seal below my gear stick, that was allowing fumes to leak into the cabin. I got a mechanic to change it - part was 25 bucks (From nissan) and labour was 50. They accessed the seal by removing the gear stick boot. Apparently there are two seals, a larger one and a smaller one. The smaller one was split.
Hope this helps.
Hope this helps.
Omg... you spent $50 just to get someone to change a rubber boot?
Dude, next time just pull it apart yourself. 4 screws under the vinyl selector cover removes the big boot, then the one that is nomally cracked is the smaller one which just slides onto the gearbox.
took me 3-4 mins max.
:bananaman
You used automatic transmission fluid in a manual box? Is atf not too thick?
The ATF is used in the Transfer case on the GTR box (at the rear of the box) The gearstick enters this part of the box, and it is quite smelly if there is a leak.
The front of the box is for the gears, and will use a manual gear oil (redline is good)
If you filled them around the wrong way, or used one oil for the whole box.. it would need to be flushed.
And $50 to replace the inner boot.. bit steep.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
