Does anyone know what price I can pick up a set of clear side indicators for my 33 here in canberra? I am almost about to buy from the forums coz I want some and there goig for a 100 bucks on here. Problem is there on the gold coast and that involves the sending/transfering of my hard earned dollars and hoping there is no bad trade.
Just thought I'd throw this in:I'm here in Sydney,getting TOTALLY :Owned: by the crap weather that's coming in...which would be no big deal,'cept I'm tring to get a trackday at Eastern Creek happeneing...FARKIT!! And I'm on one of those $2 for 20 minutes of Internet thingos....and I'm probably due to run out of....LOL!!!
I am back at work again cause someone was sick (yet again) so i am left to pick up the shit, and i am seedy as crap. those bloody uni chicks are all nuts, and i cant keep up. drinking that is they wont have a bar of me, lol.
If you cant keep up there is always sharing with your mates
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
