or maybe instead of people making useless threads that lead to things that have already been said they should see if theres another thread that is similar and post in there? for example, just make a newbies thread where people introduce themselves instead of having about 5 different threads of people introducing themselves, i think we need to cut down on the useless threads, no offense to anyone but it just seems to me that im reading the same thing that has already been said in another thread. (im just saying what others are thinking) im done whining now :P
Crew - for those of you who know Bec, which is most of you on here, it's her 19th 2moro, Saturday 12th March.
Make sure you wish her well, give presents, send her an SMS or something appropriate.
Batteries not included
