thats not good i would like to keep the value of mine up.
yeah ditto! its caus every day new skylines are imported.. and when u think bout it.. none of them are leaving, so we gettin full! O, and also the petrol.. bloody Johnie.
*looks at people with 15 year old GTR's*... you ruined my resale value bastards! :P jokes
Depreciation, the cars are starting to get really old in Japan now and are worth stuff all, which means they get imported for cheaper. 2 years ago a 1999 R34 GTR cost you $100,000+... you can now pick them up for a touch over $60,000 (same price R32 GTR's were 5 years ago).
Hey JoN - be good to see you mate - in a GTR!!!!
The only thing better than an r32 2 gts-t is a R32 GTR :D
Richard how are ya??
Yeh hopefully wont be too long now. Once i get it i will be up for a few NSW SAU track days so hopefully might see you guys up there
im always buying you food at the jerra leigh! goddamit i dont even know if you have a job! jks :P yes i have a j-o-b and work at telstra, i give info on (if anyones seen the adds or stuff on the news bout it) the new legislation about workplace and industrial relations reform policy and other things along those lines. started today and only had to work 5 hours but because it was advertised today i only got 3 calls! yay! but will be working 5 days a week in dickson :) the add is a long mofo and says "workchoices" numorous times. its not as good as eb and doesnt have its "benefits" but ohwell had to give it up some time... i shall have my line soon :) but wont put a date on it...mayhaps early next year :)
and leigh i know your going to say something like "everyone get off the roads" or "im gonna catcha bus to work" or "be afraid, be veeerry afraid!" but i thought id beat you to it :)
Edited by SKYLVIA
congrats dude pity i am no longer working at the ACCC which is in the transact building its like a 1 minute walk to the dodgy telstra building :) oh well
also i wouldnt say that about your driving thats reserved for gus :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
