Yep Aircraft(Chopper) Tech in army was what i was going for, talked to a guy in the Woden recruiting office about it and he said it was the most challenging and the certificates at the end were the most rewarding. They are even fast tracking people applying for this job because its in such high demand...
Slept so bad last night, couldnt stop thinking about it. If it was something I could work on and fix id be fine with it but like leigh said, cant do anything about it which just makes it harder.
I'm still going to go for the defence force though, the navy recruiter I had my interview with went through the exact same thing as me (he's red/green colour blind aswell) so he gave me his number (*sings* "in the navy") and said he'd help me out with what options were available and which ones would interest me the most out of those. Pretty much my only option if i really want a decent job in the Defence Force is if i go for officer but most of those are just desk jobs which goes against the whole reason i decided to join DF in the first place, to get away from Public Service jobs. Bah disappointing...
Im only 19 Skylvia ;) Yea its a fail once fail forever
Edited by Baconer
just got my quote from trojan. $7400 for fairly standard rebuild with forged pistons, $8600 to do the rb24 build :S plus aobut a grand for a new turbo as mine is fcuked dunno whether its worth going the rb24. im going to be struggling to pay for either i guess heh
or the other option is to get a import motor to replace yours, or just a reco job with out the extra bits... Good luck motor rebuilds suck. Done the mini a few times now, just because its a mini doesnt mean its not a pain, so small and fiddly. Good quote though
Tried pro engines in qbn?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
