true but with a company discount it works out reasonably good. As miss_petepie said if you fly lots it's well worth it... over the past 3 weeks i have been on 9 flights >_< with another 4 next week... plus the big thing is qantas club has it's own checkin line so no waiting in the 5km line to checkin WOOH >_<
Had an interesting experince tonight. I Pulled up at Bunnings in Belco, and a Magna wagon pulled up next to me. The guy and his wife get out and ask me a few questions about my Stagea, saying they're in the market for one and so on. Turns out he's John from Trojan's cousin, and he's going to check my car out when I finally get around to getting my manual conversion there so he knows if he will fit in it and if he likes it. It's cool how much of the right sort of attention my car gets.
my interweb is broken :kiss:
does anyone know if i can just take the broadband modem into a telstra shop and swapsy it for a new one?
If telstra supplied it, and its actually broken - probably. Depends on the shop i believe as some of them are franchised and being franchises couldn't care less about their parents customers.
Ring ahead if in doubt.
and how do you knows its the problem?
yeah i had to wait 2 weeks to have my new net put on at my new place but all is well now. Have adsl 2 and 21gig to burn a month
even though i don't download much anymore, i still hit 40-50gb a month on transact 2mb cable
i couldn't live with 21gb a month on 24mbit
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
