My newest battlescar on the ute haha
First scar was the rust and axe/tree limb damage (when we were fixing the clutch we through it would be fun to take an axe to it, it was indeed fun) then 2 mates of mine thought it would be even better to try body denting it, they used a tree branch 3m up to jump. That was funny to watch, not to experience.
Next was back before it had started raining and the paddocks were completly dry so sliding around would make massive clouds of dust that looked like crazy tornadoes, anyway i continued sliding after going a bit crazy and could not see more than 2m in front, unexpectedly I ran into a tree stump. Took out the front bar, light, bonnet latch and radiator but luckily we had an old fairlane lying around so was just a matter of swapping parts over :thumbsup:
And the newest one is the windscreen, the car wouldn't start a few days ago and was stuck in a ditch, so i was trying to dig it out in the rain, after a few minutes i cracked a shit and smashed the windscreen in with the shovel and here it is today:
nice and slippery :spank:
Love this car, it just never dies.
Edited by Baconer
Haha yea its very refreshing except when it rains and im blinded. Probably better cooling with the radiator aswell. Took the exhaust off aswell, hard to hear after a couple mins of driving it :)
Used to have a problem with the car over heating (was a hole in the radiator) so I took the thermostat or whatever it is called (spring thing that is between radiator hose and engine block) so once the car is going it can rev continuously hard pretty much until i run out of petrol.
Good fun, built a track aswell which is great when dry but in the wet you just understeer on most of the corners which is pretty scary considering the track is marked by solid gum trees.
So she got her little beast out on the track... i want photo's of the day also any times :) pm if you don't want them up here :rolleyes:
hahaa that looks like awesome fun :D
on a different note, me and Cassi went to wakefield on sunday... we decided we wanna hire the track and have our own track day :D so no one watches us lol
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
