Could you please email it to [email protected] , i got it off Leigh a while back, but both of my copies have dissapeared and it would make it a lot easier getting the car back on the road.
its 24mb, too big for email.
I tested it and it was working, now its going html again... however, if you click on it to open it, it will (should, worked for me) open in your adobe reader, then you can click file save etc.
Let me know how you go, if you still cant get it, I'll give it to you on a thumb drive.
datto what side of town are you on... if you want my service manual let me know Ill put it on disk for you, I am belco way. Not even sure if it will help but hey, ill check tomorrow if I can zip it to fit into a 10mb file to be sent via email unless you set up a 1gig account with yahoo, gmail, or hotmail, check torrents as well there seems to be some fast software and manuals there as well.
I have a proper account with hotmail, i think its 2 gig, so it should be fine, but i live in Monash, so it would be easiest to get it off Michele. Thanks anyways.
Michele, ill give u a call when i get the chance. Thanks
hmm just browsing ebay for rims as i do and came across this vendor selling heaps of the Buddy Club P1 2 Racing rims in 19" for like $1200 wtf. I nearly bought a set of these in 18" when i had the skyline and i thought i was getting a bargin at $2k :P
either way seeing these for sale at that price makes me wish i still had my line :D (not sure why they are saying they won't fit a skyline without adapaters those offsets seem fine ???)
http://search.ebay.com.au/search/search.dl...&category0=
hmm just browsing ebay for rims as i do and came across this vendor selling heaps of the Buddy Club P1 2 Racing rims in 19" for like $1200 wtf. I nearly bought a set of these in 18" when i had the skyline and i thought i was getting a bargin at $2k ;)
either way seeing these for sale at that price makes me wish i still had my line :) (not sure why they are saying they won't fit a skyline without adapaters those offsets seem fine ???)
I bought a set of 18" jdm wheels a while back, they came off a JZA80 Supra. The back ones fit, although I would've had to roll the guards but on the front I would've needed fat spacers. Not sure what the offset was on them but they sit nicely on my brothers Supra now. :) (the b*#$*rd)
I'll probably regret putting this here lol but here's my BB Audition vid for anyone interested...
http://www.bigbrother.com.au/voting.html?memberId=518736
To nominate you need to register... takes less than 1min then you can nom whoever you want but can only nom a person once... just need to click "nominate for BB08!". you can also rate vids out of 5 stars...
You dont HAVE to nom me, but if you dont...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
