Probably do one in the garage tomorrow once the housemate has gone to work :P the neighbours kids do it so I don't see why I cant.
So glad the rego muffler is off now, I was driving it around and wondering if it was even boosting.
Now I have time to do stuff non rego related to the car.
By "do stuff" I mean drink and stare at car. :cheers:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
