Probably do one in the garage tomorrow once the housemate has gone to work :P the neighbours kids do it so I don't see why I cant.
So glad the rego muffler is off now, I was driving it around and wondering if it was even boosting.
Now I have time to do stuff non rego related to the car.
By "do stuff" I mean drink and stare at car. :cheers:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
