Its funny how ACA wont publicise anything about a "Family vehicle" rear ending/destroying a VL turbo, but if it was the other way around you can imagine the fuss they would of kicked up and the hoon labels that would of been thrown at the VL driver.
That VL was immaculate, very unfortunate and feel sorry for the bloke :( can imagine just how upset hed be.
Yeah the passengers should be buying lotto tickets. Lucky there werent kids in the back like lots of other cars have on the way to the nats
Id say there will be a few dangerous/neg driving charges in there. Hope the driver learns a lesson!!
Edited by k_d
What category is that EVO in .didn't think its a summernats type of vehicle.
It could be in there for lots of reasons, a sponsors car, or someone camping, or a trader etc. Or even a sound-off car. Just cos it's in EPIC doesn't mean it's entered in a driving event like burnouts etc.
I saw they did the same to a brand new 86..... thinking that they would go onto a 3-6 month waiting list just so they could destroy it with speakers in every orifice.
They need to make a turbo charged model. Not enough power for what its trying to be. Bring a 200kw version plox.
Absolutely Speechless :woot:
Saw this link in another thread. My heart missed a beat.
Who would like to go halfs in this?
If I could afford it myself you would never have seen this post.
Sit down R32 GTR owners and Click smiley Face above. OMFG !!!!
