The way these precision turbos spool up wouldn't surprise me if you got less lag than with the twins.
But each to their own.
I was that way for a long time and after 2 different turbo combos I wasn't happy with I eventually switched over. I found the twin upgrades were the worst of both worlds - laggier than stock but didn't have enough punch up top for me.
Well helps you only need to buy one of everything!
I found it similar or cheaper than the twins. Makes everything so much simpler. If I wasn't stupid and chasing power I'd have gone the same setup that Jez has or maybe one size up (haha again chasing power I can't help myself).
Im Just going to put this here. Am i the only one that HATES WITH A PASSION people that are "trying" to sell their car and they put artistic shots of the fker that show nothing of the car. Im talking like looking at one wheel down the side. How do they expect to sell it when they don't show the car properly?
Free TV dumping is awesome!!! Have done 3 CRTs in the past months and a HUGE Plasma yesterday.
To think they used to charge at least $15 each.
Up Yours TINY !!! :nyaanyaa:
Aww what was wrong with the plasma? :(
Was so funny today... one of the TV's was the heaviest TV in the history of TV's... struggled big time! When we dropped it off the little man even got off his forklift to help us because we looked so pathetic :laugh:
Got it for Free, had CRAZY colours all stripey on the screen even with no antenna plugged in, couldn't even get a picture, would cost $100 just for a Pro to look at it & yes it was heavy as all Buggery. Extremely unfortunate. :(
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
