bahaha noooo from dancing with teh ladies all night Saturday ;)
then 9km on the cross trainer early Sunday morning (I'm f**king horrid with cardio lol)
Yeah I feel the same about cardio...(km's...I would have a heart attack!
I get my cardio mixed in with my MMA training. I can not just run around an oval or on a treadmill etc. Way too monotonous!!!
When you're as out of it as I usually am the time of morning I'll do cardio, it's not that bad :P but if it were after midday when my mind has finally booted up properly, it ain't happening. Hours of trance podcasts help a lot too!
Me no train in the mornings. I am not a morning person at all. LOL
Only on weekends for me. I struggle on weekdays thanks to farked sleeping pattern (if you could even call it that, lol). At least on a weekend nothing forces you to get up until your mind is awake enough to care lol.
I am not awake until three hits of caffeine!!
I love cardio - and fitness training ! I cannot think anything better to do of a morning then to get on a tradmil and run for 35kms or even run around the lake.
Anyone who has seen me knows I'm telling the truth :P
I'll hit the pre-trainer before gym in the morning on a weekend. That's somewhere around 250mg of caffeine, or just over what you'd be getting from 3 shots of espresso. Plus is has other shit in it that can't be good for you LOL
Ah, but do you even lift? :P
I get my "lift" workout every time I need to chuck a piss m8.
Wont be dancing when you get the invoice Mik - sort of like Dafuq :huh:
Espesh as your a DIY and don't normally get the bill
Its ok, ive been saving for ages as i havent got it there as soon as id liked.
And sometimes you just gotta pay the pros to get it all right.
Being a tradesman i have no problem with that. Its only fair.
And after reading about them here and there i have confidence they will do a good job.
Watching my car being towed i noticed the left side of its face droops ever so slightly.
Edited by D.I.Y. Mik
Hahaha! i was thinking the same thing.
Its already had some plastic surgery.
I think it had more than a stroke........ well shes been in the wars thats for sure. :pirate:
Actually stressing a bit, i hope i did all the right things with the right bits, and i didnt give them a headache to fix.
Its because of all the work and money and work... back breaking bloody work doing the shed so i could do the car.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
