Hope it clears up today. Wanted to go for a drive, maybe north side, and check out Rosie.
Friggin windy & rainy still but a glimpse of blue sky - hopefully blow over
It's sunny over this side - I'm heading over to Rob's (2mins from my place) and working on Rosie (Spark plugs) - Can go for a quick cruise-about afterwards if you're heading to the North shire Richard?
Having a suspicious engine cut out at 5,500 RPM in 3rd.
Edited by RosieR34
how much boost are you running?Im running 14PSI and its still alright for a 1.1gap.Im changing mine soon and not sure if i should stay with bigger gap as it gives a better spark or just go for 0.8gap
I'm running 14 PSI at 5,000 RPM and when it gets to around 6,000 RPM a MASSIVE boost increase happens - Rob can confirm this weirdness. However, the Engine cut out has been fixed after Rob and I changed the Sparkies. I think the gap was 0.8 (Rob can confirm).
Surely 14 PSI is unsafe - I was planning to get a R32 GTR Accularator (Spelling?) which will give me 10 PSI.
pretty sure you mean an r32 gtst wastegate actuator. It's the brass fitting that controls boost through the turbo's internal wastegate.
But unless you can easily find one, it is just as easy to use a standard actuator and a bleed valve to get 10-12psi. If you are running 14psi someone has already been fiddling with your boost control, but it's not really like an instant turbo death sentence
32 GTST Actuator. You talk to me...
I honestly think it is all plumbed in wrong and is bleeding all actuator pressure back into the BOV return pipe, therefore Not opening the Gate.
I thought maybe as 33 turbs seem to Splode over 12 psi maybe 34 OP6 turbs would possibly be the same safe level???
Edit* Are OP6s steel not ceramic?
um - not sure that's good value for money. Check through Cooma Diesel (GCG, Garret reps) the cost ....
I was quoted $900+ per turbs way back when.
New = $1250ea for -7's. Now they are $2300 a pair.
You may wish to join Erics GB on the HKS ss' when you find out the price.
He's doing a pair with full kit for $3k :D
(expect commission if he does Mr Deziner)
Edited by Sinista32
You guys totally lost me. So 14 PSI is too much and should be at 12 PSI.
What's this about rebuilding a turbo? Kinda want to avoid that.
EDIT: So 14 PSI max is okay - but to be safe I should be at 12 PSI?
Edited by RosieR34
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
