Lol Jeremy I'm going to go back to my first impression that you are in fact named Rosie.
Walking dead is the shit!
I actually love all zombie shows/computer games
Hey ! I don't like scary things babe x :(
I don't think they know what they're doing :wacko:
List price: $7,900, then.. will sell for $8,000 without RWC, or $9,000 with RWC, then right down the bottom... car is for sale for $13,000 with RWC and Rego, then $9,500 with RWC and clutch fitted.
ok then...
ok then...
yupppp
