Actually I just had a look and I think most of the bigger ones are moved already so the Bommodore might be ok :)
We could do one run anyway, as there are some that will definitely fit. Do you wanna pop past after work or something Zeb?
Skywagon would be perfect... but maybe we'll see how we go first so you don't have to lower yourself to the dirty South, Rob :D
I have always prided myself on being able to interact and assimilate with all types, be they Respectable, Nice, Wholesome Folk or Lowlife, Scumbag Bottom Dwellers.
I think I can handle the Southerners from the deep. :P
Cheap and the right colour too.
(Above Pulsar may not be a Nismo.)
haha this was my first Car :D (but in white:() and it was $100 out of the paper :/ it had a full 2.5 in exhaust on it :D f**k im a tosser...
haha! I didn't put the cannon on :P it had stockies on it too, with 4 different tyres, I wish I could buy a far with 4 of the same dam tyre... atleast it had the bigger 1.8L in it :P
Edited by ..::R33GTS-T::..
Deal. :)
Lets go git us a gator y'all
He says in his best southern accent
You just gotta love that ..... :yes:
Thanks for making my otherwise crap friday ... awesome, time for a :cheers:
Edited by THE34T
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
