ahhhh Under 25 hey? Gotta be Enthusiastic about the motoring also.
Keep in mind that with Monthly payments, If you need to claim, you have to pay the extra 11 months out to get it. :/
Having to be over 25 with shannons is bullshit. Complete crap i don't know where people get that from. Im 22 and my car is insured with them. All they want to see is if you are an enthusiast, they ask you a bunch of questions and if they believe you are they will insure you.
JustCar are great ! Unlimited mods. I said I put on an aftermarket Pod filter and he put another 2k on top of the value. He did confess he was a Skyline owner himself :D
Rosie had full compo for 13.5k(there abouts), at $120 a month fee. no contracts with JustCar. Can drop it and get re-quoted a day later. They also refund your money if you have not claimed any days. (I'm getting $28 back woohoo! high roller).
I shall see if JustCar got any spots open! :P
HUH? :blink: ^^^ But they do Daily Drives too! Don't trust the web.
Shannons, $120 / month, 3 cars, 2 full compo, 1 agreed value, 1 market value and 1 3rd party.
Enthusiast! :D
Oh and I'm OLD!
I got knocked back when I called them for being only 20..
I'd say they get it from the website also
Read it again. That's for the ONLINE quote system. They insure drivers under 25 if you call them.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
