HEL braided brake lines. Fine for Dickson
E-bay or anywhere you can get genuine for 32 GTR
Try HEL Performance Australia. Just Under $170 for the set
Edited by Sinista32
  • Like 1
What year is your car Judd? I've been wondering if I should get new lines for the Skywags... They are 24-25 yrs old and looking a little crusty.
Works fine but... :unsure:
mine is 11/93
I just bought a HEL set last week. Was 180ish or so, though that's for a gtst. Will install later this week :)
Oh really :/
http://www.helperformance.com.au/?subcats=Y&status=A&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=skyline&dispatch=products.search
Difference of $140 from R32 gts-t to GT-R??
LOL
Also, Didnt see if anyone came out to look today...but here is some quick footage of this morning
Nice... i like how you kept the angle up that tabletop to not roost on that kid. Slower, but not chucking rocks at some kids face.
So discovered yesterday arvo I could do with some new brake lines.
A: Can anyone suggest a set of braided lines that is decent and won't send me broke? Saw some on eBay but not sure of quality
B: How does Dickson feel about them, I know I can get adr approved etc but will they be ok to pass? My last 4wd had them, they were engineered, but the vehicle came that way so I'm note sure if they just had them engineered with the suspension just to be safe?
Dont forget, if you get HEL, make sure they put the adr printed bit on the line.
It is an option you have to ask for, no extra cost, but make sure.
Thanks for the heads up
I got black lines, and the adr number is printed on a clear sleeve, in black....... >_<
Noodles anyone?http://www.canberratimes.com.au/photogallery/act-news/tuggeranong-noodle-bar-fined-for-dangerous-food-safety-breaches-20140130-31ot3.html?selectedImage=2
Edited by D.I.Y. Mik
Oh another thing.....
I took bubs to hydrotherapy this morning, after i left some guy came around to my house ( the missus was home ) with dodgy bullsht stories.
I think he knocked on the door cos he saw no car and the front window open with the aircon outlet.
He did it yesterday too. It seems he has looked at our mail and tried to guess the name of my missus and failed. Totally sus.
He is driving some old shtbox khaki 4wd ute with a cage on the back.
If i see him he will have to explain what he is up to.
  • Like 1
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
