Oh yeah :yes: modern Lego is so nice.
I bought a vintage lego train at trash n treasure, $60, expensive? when i got home i looked it up; $500 for a complete one, $3500 in the box. Its missing a couple of common bits which i have. :banana:
That Nissan motor.. i was thinking, its like two moto gp motors, roughly twice the capacity and nearly twice the output.
But it needs a turbo.... if its a high maintenance race engine, its no improvement ( apart from fuel efficiency), just a new size.
If its a reliable street car engine, then its a real winner, as long as its not incredibly expensive.
It would go great in a Lotus or similar..... no, two in a purpose built 600kg racecar! YEEEEAAAAH! :laugh:
Checked out the new IGA Drakeford the other day (because I don't already have about 6 supermarkets within 2 mins of my place lol) and was pretty impressed. It's bigger than I thought, and it's all so new and shiny :D
thanks Shell. Think I'll go there.
I normally do Woolies at Lanyon (easier than Hyperdome for parking close and don't have to put up with shopping mall crowds)
but I'd rather support the smaller traders
Supabarn near Red Rooter would be nice and close for you too, and an independent trader. I usually shop there - fruit and vegie section is awesome and it's a big shop but you can park at the door.
I like their rewards card too - I have received quite a few $20 vouchers and it's not like I even buy that much (not like shopping for a massive family!) :D
And just for you, there's a bourbon fridge :D
Anyone have 1.5m for a BNR34?
http://www.gt-a.net/fast-furious.html
Paul Walkers R34 GTR is up for sale. $1.5m AUD is a bit high though.
Edited by RosieR34
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
