Anyone know a good place to buy some Michelin (265)/(275)/35/18. Under $650 for a pair or AD08 or something close excluding federals as theyre a nightmare in the rain.
I got a good price online from Ozzy tyres for my Michelin Pilot Supersports and so far I think they're a fantastic tyre.
A 265/35/18 was around $1600 for 4 including sending to Canberra. Wasn't much difference in their price compared to tire rack after you factor shipping, customs and quarantine fees etc.
  • Like 1
"How much were they for the set, if you don't mind me asking?"
I did some hunting around in the end Bob Jane at Fyshwick were the best at $1340 all up, as I said I'm very happy with them.
Edited by THE34T
You have the RSR yeah Richard?
I'm running just the standard 595's and I think my camber probably pays a good part in shit traction.
Best thing about them though is that they hold well in the dry and they have lasted me for nearly 2 years!
Im running the RSR dan and i can't fault them. Even in the wet.
Okay folks.
It is going to be an absolute nightmare financially and physically to get the 34 registered in Victoria so I think I am just going to sell it real cheap to someone in the ACT if they want it. We only really need one car here in Melbourne anyway. What do GTT's go for these days?
I do like having fresh breth though.
The issue with rego was that i just wanted it in Vic rego so it would be easier to sell.
I was initially told that if it was an interstate car with current rego i don't need an inspection, i just need an appointment to hand in plates and they would honour my rego. Today i find out that because it was an import never registerd in vic they dont have my compliance plate on record so it will need to be a full rego inspection and ID check, which i would fail because i am in no position to spend money putting my car back to stock just to get it into another state just to make selling it easier.
I will just leave it in ACT rego and sell it cheap enough to sell it quick but still not make a massive loss.
I barely drive it here in melbourne so it's just dead money really...still...it will be sad.
Also selling mine Andy ( can't plug it enuff :P)
http://www.carsales.com.au/private/details/Nissan-Skyline-2001/SSE-AD-2909440
Do a search on carsales anywhere from $7k to a very hopefull $25k
Mine sits squarely in the middle ground (also known as the kill zone !)
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
