That's pretty impressive.. still got the plastic seat covers over it. 200k AU that's some big coin. Didn't the Z-tune build: 001 sell for 200k? Aim for a Z-Tune if spending that much. Personally the MIllenium Jade with NuRs are insane ! :* :*
A Domino's pizza worker in the US response to a complaining customer in store
Asking for a supervisor's name, Ms Averill is then told:
"My supervisor's name is 'Go F--- Yourself.' Get the f--- out of here, you f------ r-----."
If only we could all respond to complaining customers like this guy
Would anyone be interested in a local cruise for xmas? We haven't done one this year and I think it'll be good since we got a few new additions to ACT SAU. Chris and his R34 GTR, Mik with his Green Machine and Kasko with his new R34 GTT. Not to mention all the other new mods people have. Be good to show them off at least once this year with a small cruise around the cotter and such?
  • Like 1
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
