Since there's been no mention or reference to Buster's Drag Day on the forums I thought I'd stir the pot... Do you think John's 300Z is going to do his proclaimed "easy 11's"? And what will pop on the motor? Will Adrian have enough nitrous/clutch for the day? Can Pete "Da Man" live for more than an hour without snapping boxes + driveshafts? Will "Dirt Garage" be going after the low mount record? Can Bu5ter pull off 128MPH in the Falcon wagon?
Place your bets!
https://www.sau.com.au/forums/topic/54534-the-smack-talk-drag-day-thread/
  • Replies 212
Ok Chris - In Order:
In short, no. I think "Team Trackday's resident Septigenerian" is going to find it harder than he expects on Saturday.
Enough Nitrous? Actually, my bottle is mostly empty - off to Robbie's house tonite I guess. Enough clutch? I reckon she'll be apples :D
I hear that the auto's in now and I can't wait to see the times fall!
Unfortunately, no.
Buh-five-tah can do whatever he wants as long as it's Flintstones POWAH!
Will Doughie run a flukey 10 on his 1st pass and be made to sit out for the rest of the day?
hehehe....
Adrian
stickers are better Brett
You guys are lucky the datto broke a drive shaft on sunday from too many big rev launches
otherwise you might be in danger of dying of laughter.
Have fun poofs!
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
