Ok, I *think* I know the answer, but time to check, before I spend $$ etc
R33 '96 Series 2
T3/4 Hibrid Turbo
FMIC
Stainless Ducting
3" high Flow, all the way through
Mines ECU
Adjustable Fuel Reg
Pod
Etc, Etc.
When I'm using the engine to brake, usually when i've been doing quite a few k's at motorway speeds (100-110), I get random pops/almost backfires. Usually only one or two, when slowing down for a roundabout etc.....
It's noticable to me, but not to an uneducated passenger, so they're not too noisy.
I think it's because i'm running rich atm, and am going to be changing ECU & getting a retune done soon (Which should fix it, and a little more power, I hope)
(IIRC, I was running 12.5's on the mix at the last dyno)
Any other thoughts?
https://www.sau.com.au/forums/topic/54658-pops-backfires/
mine does the same mate ...
just unburnt fuel passing into / through the turbo and igniting in the exhaust ...
when you have LOTS of fuel going through, then you get, ahem, nice flameouts ...
slightly more than a popping noise tho when this happens .... a friends rx-7 in the uk used to shoot flames on each gear change ..
lol
https://www.sau.com.au/forums/topic/54658-pops-backfires/#findComment-1069349
My GTI-R does it. I love it! It sounds great on gear changes. Mine is caused by two things, free flowing straight through exhaust and rich as tune. Don't worry about it too much. Unless of course it has only just started happening which may indicate a problem.
Richard
https://www.sau.com.au/forums/topic/54658-pops-backfires/#findComment-1069800
Due to your car running rich, the unburnt fuel when you back off the throttle is left in the chamber, So once your throttle body closes theirs no more air only leaving fuel to hit your nice hot turbo. Which ignites and back fires. no mager dreamer, as lots of skylines do it. You should see what happens when you have a 700hp GT3540 and that fuel hits that a full noise. Its pretty awesome flame about 1m long.
Just make sure your exhaust sticks out far enough from your back bumper, other wise it will melt it eventually.
https://www.sau.com.au/forums/topic/54658-pops-backfires/#findComment-1069991
thats more a result of a sh|t tune.
my car doesnt pop/backfire or flame and it has no cat
NOPE, don't think so. mine pops away quite happily on occasion as a result of a very free exhaust and nothing to do with my tune which is near on perfect 12:1 AFR's thanks to PFC.
https://www.sau.com.au/forums/topic/54658-pops-backfires/#findComment-1070710
Interesting leg you're standing on. So you're telling me that my car isn't actually tuned properly and every car in victoria is so therefore they don't do it?
Anyway, lets not start a shitfight. Agree to disagree but I can tell you there ain't nothing wrong with my tune :uh-huh:
https://www.sau.com.au/forums/topic/54658-pops-backfires/#findComment-1070890
I think you will find it has absolutely nothing to do with a sh!t tune. If in fact it’s probably a good tune if your car does pop/ blow out flame.
Because if it does then you know you don't run as much of a risk of leaning out your motor and killing it, as compared to no back fire, were you don't have enough fuel into the engine causing it to run lean.
If you watch the Japan drag racing I think you find just about every one of their cars running any were from GTS-T running 11 to GTR running low 8, pop and back fire every gear change. Because they tune them rich, for reliability.
https://www.sau.com.au/forums/topic/54658-pops-backfires/#findComment-1071112
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
