  • Replies 196
Hi Steve-SST,
I have an RB25 with ARIAS pistons, Linished, Shot Peened and Cryo Tempered Rods, HKS GT 3040, HKS topmount manifold, PFC, Tomei Poncams 256/9, 550cc Sards, Greddy/Trust Plenum, Ported Head Iski valves prings, Micks MC bar & plate cooler 100mm, E-Boost and Trust Type R W/G 45mm, Q45 Throttle Body, Q45 AFM, 90mm Fujitsubo Exhaust, 90mm dump & very hi flow cat.
Max I could get out of it was 330rwkw @ 21 PSI. (DD Dyno in shootout mode - do a search and you will find the dyno graph I posted)
Since my car is very similar spec to Pauls and Magics -
If I change from PFC to Wolf - am I gonna get 50 rwkw increase ???
Cheers !
/edit = PS I run 118 mph (18PSI) - but I am CRAP at drag racing :(
The post stands it did make 511 on Speedworks dyno and as Tristan said read the following posts and you will find out what it made in shootout.
Speedworks claim their dyno is the only one thats right i think our dyno is but you guys make up your own mind.
Hi Steve-SST,
 Cheers !
3040 rated at 500 at 1bar, cant see why a wolf and the right tuning it would not get 440rwhp. a bigger fuel pump might be needed along with a better head gasket
Just wondering, if injectors are run at or very close to 100% duty cycle, are the spray patterns adversly affected?? Also, I noted that BOOSTD mentioned that increasing the fuel pressure by higher than 10% screwed the spray patterns, but I dont see how this is appliciable if the standard reg would be boosting the rail pressure during boost situations anyway??
330kw = 442.5372hp!
Dunno how many times I have said this....
Forgot to add - HKS 1.6mm head gasket and Bosche 040 pump.
I want the 380rwkw you guys keep talking about with Garrett GT30s - ha ha
The only real difference is the Wolf - and I can't see how it can be done !
But hey - that's just my opinion
Time a Mod locked this thread and wait for the Drag slip but then there will be hidden NOS storys etc.
Get real will ya !!!
You and your chronies get great pleasure in trying to make yourselves look ahead of everyone else.
You are the one started this thread with a claim of 511rwhp knowing that it was a false reading, inviting everyone to scrutinize the result.
It turns out that the result is nothing out of ordinary and is replicated everywhere else, with the exception of difference in injector sizes. Big farken deal, next time you are in VIC, let me present you with a plaque carved out of an off-cut 0.5mm steel. If you try my earlier suggestion of cam gear modification i will upsize it to 1mm.
To finalise, why is there a 40 degree difference between the intake and ambient temperatures...? It was explained to me by a DD rep that, 40 deg. difference would add an 8% to the reading.
In short, move along fellas...
Emre, STFU, from the being steve and magic1 said that the reading will most likly be out as SPEEDWORKS (the dyno in which was uses @ PAS) reads higher.
WHY DOESNT EVERYONE get over themselfs? I ****ing sick and tied of people bitching just becuase YOU AND YOUR TUNER CANT make the power steve and sst can.
like steve said someone lock this thread, its got out of controll its kind of like a FLAME war between everyone not in W.A and the boys in WA,
You have absolutely no idea about anything, so i susgest you STFU.
Its got nothing to do with wa versus other states, its the inability for ppl to answer questions.
Tristans car will do the times, just give the guy a break. he didnt start this thread btw.
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
