  • Replies 237
Nice effort Tristan, for a street car that's more than enough power - especially in a 2WD.
That dyno mpg shows a few things which have been a source of questions though. I can recall Paul or Steve saying that the reason why intake temps are so high on their dyno is due to the fact they run it with the bonnet shut. That run clearly shows the bonnet open, and if you look on the dyno sheet it shows the intake temp up at 63 degrees.
To the best of my understanding, all dyno's record an uncorrected level of torque, then reference that to RPM and calculate power. After that primary calc is done it then factors in the correction, which is based on humidity, temperature and altitude. I know that's a basic rundown of the whole she-bang but for the sake of this arguement it will do.
If you run those weather conditions through a dyno correction calculation it actually multiples the amount of power recorded, mainly due to the extremely high intake temps. Hang on will do the math and post the actual correction factor.
So just a quick question - where is the intake temp probe situated?
Don't be hasty and think I'm having a go at the car, it's owner, the workshop, your pet etc. I'm more interested in the correct way to extrapolate consistent data from a dyno, moreso than what is currently being shown.
Attachment of the graph: http://www.skylinesaustralia.com/forums/at...achmentid=25240
LOL...for gods sake you are in a workshop...take the tie off:) i flinched when i thought you were about to lean over the engine bay, i have weak nerves so pls dont lean over a running engine with your tie on :)
Seems to come onto boost nice and hard....what boost was the thing running?
I too cringed like a little girl when i saw dude in tie lean over the engine bay!!
I'm over the whole scene of this 511 hp stock injectors car cr*p. Until someone post up a mph that reflects the representation of the claimed hp. So until then it's still a claimed effort , and i'm claiming mine to have 900hp atw, and i'll post the dyno sheet tonight, But don't hold your breath on that one either.
hungry6 your a tosser. In the other thread tristan said that the 511 was an overinflated figure. If you watched the video, youd see it shows 438rwhp, which is the CORRECT figure. And yes on STOCK injectors. So take you 900rwhp dream machine and fly elsewhere, when you actually have a car worth posting about, then dish out on others...
tosser
josh
be nice everyone. Im not going to be nice this time :)
boost seems to come on like a hammer!
My car is sooo nice and progressive with my GT30 compared to that, very savage!
tough to drive on the street?
Doughboy. the air probe is right in front of the compressor housing, my air filter is causing a minor restriction so i took it off before the dyno run.
Roy. Peak power the turbo is running 18psi
sorry dave wont wear a tie next time.
Crack. about 6500rpm to get that figure
Hungry6. . <- you
D1 RX7. nice bit of chop dished there.
r31nismoid. you dont have to pump the clutch to get it to break traction, your coming to perth, you can have a drive.
tristan
']hungry6 your a tosser. In the other thread tristan said that the 511 was an overinflated figure. If you watched the video, youd see it shows 438rwhp, which is the CORRECT figure. And yes on STOCK injectors. So take you 900rwhp dream machine and fly elsewhere, when you actually have a car worth posting about, then dish out on others...
tosser
josh
Then why did he topic this thread with 511 rwhp?
There is only one tosser here and it aint hungry6
Prolly shootout mode which is made to compensate for inconsistensies on the day of the dyno run.Correct me if i am wrong.
You are wrong.
The 511hp was made at Perth Auto Salon using a hub dyno.
Autosalon figures should be taken with a large grain of salt, cuz in the end, their only purpose is to put on a show.
The 438hp was on a dyno dynamics dyno in shootout mode. Which is a fairer representation of the cars true power. Since Dyno Dynamics dynos are widely used when comparing HP figures.
The first thread said 511rwhp on stock injectors, people questioned the figure and wanted to know how it could be done on stock injectors.
It was then acknowledged by the workshop in question that 511rwhp was a BS figure and the cars true power was ~450hp, which has been shown on the recent dyno.
This whole debarcle is over a big HP figure being made on stock injectors, people questioning how it can be done on stock injectors and other people not telling how it was made.
I'm just here to enjoy the resulting show :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
