  • Replies 237
Oh my god i feel ashamed to be west aussie, How can please some people lay in bed straight at night.
I hope the rest of ozz doesn't judge us all in the west the same as few intent on making a joke of us.
Is that because you guys don't use Jim Berry clutches or because we drive our own cars at the drags :spcow:
then why does everyone suggest not running above 90% duty cycle?
If the injector is running at 90% then there is insufficient capacity left for acceleration enrichment. When you push the thrott le down the ECU adds more fuel for a short period of time to help the engine accelerate. If you dont add any fuel the engine will hesitate and only slowly accelerate.
If the injector is running at 90% then there is insufficient capacity left for engine temperature enrichment. One of the ways to cool down an engine is to add a bit more more fuel. That is not possible if the injector is already running flat out. One of the things we do with the V8SuperCars (that why they trail flame out the exhaust on overun. We add extra fuel to cool down the cylinder heads, you can see the difference on the data logger.
If the injector is running at 90% then there is insufficient capacity left for engine protection. If you program in some protect strategy for overboost, excessive air flow, high water temp etc there is no extra fuel available to save your engine.
In an extreme case there may not eve nbe enough fuel for cold run enrichment. Without extra fuel until the engine warms up it will run like a dog, stall, may not start and generally be real pain in the ass when it's cold.
because thats what smokes the coils in injectors... an injector running over 90% d/c will get too hot and eventually fuse its coil..
Actually the fuel flowing through an injector is what cools it down. So it could be argued that more fuel through the injector = cooler running.
that is a load of crap. A injector holding wide open is not gonna overheat and burn out haha.
That's not quite right either, a solenoid is an electromagnetic device. Holding it open continuously does not allow any magnetioc field recovery time and it eventually won't close against the boost pressure. There is a big difference between 99% and 100% in that regard.
Hope that helps:cheers:
yes the laws do i ply but i think dynos anit dynos over here and i'm fast becoming a believer that the 1/4 is the only true lard stick as dyno figure seem to matter very little anymore with so much variation.
In an extreme case there may not eve nbe enough fuel for cold run enrichment. Without extra fuel until the engine warms up it will run like a dog' date=' stall, may not start and generally be real pain in the ass when it's cold.
QUOTE']
has magic1 gone down the 1/4 yet since it recorded the (true or false) figure of 511rwhp. I believe it went a mid to low 12 @ 120mph with 400rwhp (unsure of whose dyno) ???
265 rwkw (355 rwhp) = 11.9 at 119.8 mph in an R34 GTT
So 511 rwhp should = high 10 at ~130 mph
:cheers:
Ive read in numerous places that an injector over 90% will suffer the following
1. Coil overheats, the size of the windings in an injector coil are very small they were never meant to be on 100% of the time. Fuel flow cools an injector but being held at 100% the heat from the coils will far outweigh the cooling capacity of the fuel in the localised area of the coils. Leave them at 100% for too long and they will smoke.
2. At over 90% on almost all pintle injectors the injector will inevitably hit a static point were the injector hangs at half open half closed, which will actually have a hell of a lot less flow than an injector at say 75%. You do the maths high duty cycle then BANG into static half open position will cost you a motor.
Both are documented if ya wanna go hit google.
Peace
what kinda nut runs his engine at full throttle during warmup?
Magic1,
I think what you said along these lines might have needed some qualification to stop squabbles, you put some mega buck ecu's in the same basket when you say;
"....because the Wolf computer has far superior fuel management than any other compter full stop. "
Instead I'd suggest that the Wolf ecu 'may' have some advantages in fuel control over similar priced ecu's. When it comes to the Motec's and others it isn't in the same league but, at the price no one expects it to be.
Magic1,
FFS... All it does is to batch fire the injectors as it doesn't have sequential drivers for 6 injectors.
If that is an advantage, a lot of ecus in the market are a damn good thing.
Now, if Wolf is such a good piece of gear, why aren't we being educated on them here...? Why aren't we hearing the good points of the Wolf against the other ecus, similarly priced or not...?
I thought being the main Oz dealer, that's the best thing anyone could do...?
im coming over.
23rd Nov.
im going to start a thread about it later in the week.  :P
What do you expect to see when you are there Ash...?
Here is a premonition :
You are going to see a Gts-t pushing out ~430rwhp. Whopse farken doo... Is it a good effort ? YES. Is it unique ? NO !
Now, the BIG talking point here is that, it's done on stock injectors. Another whopse farken doo... What is the infatuation with farken stock injectors...?
Batch fire is an early form of injection where all the injectors fire simultaneously for each crankshaft revolution, so you have two squirts from an injector before the intake valve opens.
Now. there are arguments on the advantages/disadvantages of batch fire vs sequentilal fire injection. Sequential fire is adopted by all major manufacturers today, because of its positive effects on emissions and fuel consumption. Maybe, this should be more of the talking point, rather than "look... xxx rwhp with stock injectors."
I would love to see a Wolf dealer come out and correct the ramblings above, or even add to it.
Magic1,
Can you confirm your 120mph pass on the 1/4...?
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
