  • Replies 199
Thanks for the support guys.
*spanks Duncan* cept for your ya wally :) nah jokes
I've been trying to get my hands on a trailer so I can whip around a track with it in the meantime. Trailer is low cost activity and the tyres aren't rego-able so I figure I might make some use of them :)
Anyone know if I can go on the track without rego ok?
yeah no rego and track = no problems, although the scruitineers may give you more greif. I think the EC/ARDC track days would require a log book if no rego but everyone else is OK.
Trailer = not so cheap, $2k up, or you can use ours for $50 :(http://www.skylinesaustralia.com/forums/sh...ghlight=trailer
Of course it is busy for most SAU events but if it some other time you should be OK
Hey Duncan that's sweet as!
I have a private track day I might be able to go to and I'm scared the gearbox will blow up - if it does I don't wanna be paying towing so if I have a trailor .. sweet.
I'll find out when it is and PM you.
haha fatz - now you know why I didn't make your track day :)
I was testing my half working jaycar IEBC today and lost 3rd gear also.
Lol locked out of 3rd and 4th. Funny stuff... So I took the clutch out, got angry and tried to shove it into 3rd and heard a clunk, then it went in :rofl:
But now they're both squishy lol
Hopefully get engineering, blue and pink slips in april along with a new box.
someonestolecc, may be the clutch, may not....
My R31 developed some masty selector problems and I started losing gears one by one - 5th, then 4th and 3rd - basically felt like it locked out of them, to begin with they felt kind of "non-positive" when you put them in, like they were stiff and you didn't really feel a click. Took a lot of effort to select and deselect gears. Also the lever wouldn't return past the neutral next to them, as in sideways- it would sit in the neutral between 1-2. I got it to loosen up and kept having issues with top jumping out, then that seemed to clear up....
Finally I reversed into a car park and it jammed into reverse/neutral space above it, and refused to go up/sideways to select the other gears. I had to drive about 3kms in reverse to get home....
It stayed like that for 2 months then one day I was sitting in the car cursing its capricious nature when I punched the lever and it loosened up, lol...
Now it works ok, but when its cold sounds like something is being spat around inside the box, like a loose chunk of something. Nasty.
Yeah that sounds about right actually!!
non-positive I call that squishy!! it started with 4th, now it's spread to 3rd but 3rd is intermittant squishyness.
Last night it wouldn't go sideways in neutral as I usually just wiggle it side ways when I get home as habit to feel if it's in neutral.
Also it gets stuck in gear but it's all intermittant - haven't had it jump out of gear yet but 4th can be easily taken out of gear without clutch (at any revs).
Mechanic said sounded hydraulic but he'll have to drive it to check - obviously over the phone ain't the same but I'll keep this thread posted incase anyone else got the same issues.
Cheers for the response - out of interest what do you think your problem is caused by ? And have you drained your oil and checked the plug to see if anything in there has shredded/let go? I don't wanna drop my oil just yet because I changed it in the last 1000km heh ... my car gets hardly any mileage now :
Thanks mate - I'm planning a celebratory cruise next month when my car is scheduled (ie when get my company bonus) to be engineered and rego'ed.. so you'll have to come along :)
If the bonus is big enough I might put in an organic/brass button clutch and get a new or recon gearbox but even without those things I'll be cruising as soon as it's legal (even if I don't have 3rd and 4th gear).
Brass button clutch = bad idea. You are not meant to slip the clutch with a BB, which means they are next to unstreetable IMHO and only really good on a track (be that racing or drag). Given you drive your car on the street -- and if I remember correctly, want to do a little bit of dori dori -- you want something you can slip.
LW.
That's exactly what I was thinking but I've never used a BB clutch.
I might search up what people are using for around 200rwkw + track abuse.
My mates 'organic' the local place put in for his r32 feels nice, the friction point/pickup feels like it's about 4-5mm without being too hardcore.
But what the hell is an organic? :)
I have BB clutches in both my cars. I reckon they aren't too bad for street. I haven't had a car with an organic clutch for probably 5 years though so maybe I'm just tough :P...
Organic generally means not brass or ceramic - The stuff that stock clutch plates are made from.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
