  • Replies 98
Hi All,
Was going to post a seperate thread but I thought posting in this one would be appropriate!
It's time to get a new exhaust/muffler for my R33 RB25DE GTS4..
Currently it has a Genie tri-flow/reverse-flow ('turbo' style) muffler, 2 resonators and 2.5" mild steel piping for the straight section, then it steps up with a bolted flange to 3" at the bends (I got it off a mate who changed his muffler on his gtst, which was 3") trumpet style, haha. Muffler has a loose baffle now and sounds crap, and i'm sick of the drone. The ideal new setup would flow a bit more freely than the stock system (of course keeping sufficient back pressure), don't want to any drone at 100KM/H, however when on the pedal a little bit louder than stock would be good. But not something that will attract the police, etc.
So I'm after a new muffler/fitting. Can anyone recommend what mufflers are good for this job? are an exhaust shop in the city/surrounding suburbs area that can do it? Prices?
cheers,
chicane
Okay, just to clear up something fer me...
If I just want to give the car a slightly louder/gruntier sound than stock while idling and accelerating can I just buy a larger exhaust tip, or would I need to get a muffler aswell?
I just wanna get that deep growling sound :wassup:
one other thing, my car has a turbo (bone stock Gts25-t) if I do decide to go with a muffler aswell what is the optimum size piping for it?
dumb questions I know but keep in mind I know nothing about exhaust systems
  • 3 weeks later...
Hey guys just letting you know i got my exhaust fixed the other day, and yes Eug you were right it was the resonator. They fitted a larger one and it has completely eliminated that annoying rasping note! Sounds mad now a really deep throaty note. So if anyone has that prob which i know a few of you do, change your resonator or put one in! :P
  • 4 weeks later...
http://fujitsub.rsjp.net/search/prod-v.php...cnamID=00000523
it's 2.75" piping. What do you guys reckon?
hey davor,
2.75" will be very droany on an NA
i personally wouldn't go over 2.5" (i can remember by old 3L NA supra that has 2.5" and itself was very droany when cruising - annoyed all my passengers)
i think the secret is to have as large a resonator as you can to keep the droan down but keep the flow and exhaust note
:D
miscommunication possibly?
by tip i mean muffler... not just ricey chrome metal wrapped around teh exhaust.
a mate has fitted his civic with a tip (muffler) whatever u want to call it. and it has changed the sound.
tip ie. the tip that sticks out.. muffler cannon... whatever
thats how everyone else have been referring it to in this thread.
if not my bad and i am confused and got no idea what ur on abt
Misunderstanding of basic terminology on your behalf perhaps.. Never have i heard a 'tip' being the muffler.. :confused:
ok people this thread has gotten way off track - it seems that some backpressure is good with NA engines, and it seems that 2.5" diameter piping is ideal as well.. lets get some actual useful knowledge in this now!
What mufflers are a good choice? If you have got an NA skyline, and have an aftermarket exhaust, post up what muffler you have (its specs as well if possible) and what you think of it...
cheers :rofl:
i got a 2.5inch magna flow cat back. one resonator. 2.5inch inlet with twin 4inch tips. Looks the sh1t and sounds even better. Made a minor improvement in performance. CAI made a better difference. Cant wait til i get extractors but that aint gonna happen til a group buy takes off.
Please stop saying you need some back pressure on the exhaust of NA engines... As was mentioned earlier you don't need any back pressure, as this is just wasted energy, what you actually want is a small enough pipe to allow exhaust scanvenging.
This is where the momentum of the flow of exhaust gas in the exhaust effectively helps suck the gases out of the cylinders. This is of benefit at lower RPM where the volumetric efficiency of the engine is low.
Putting a bigger pipe will help peak power at higher RPM where volumetric effieciency is higher but at lower RPm you will loose out and have a less driveable engine. Again as has been said there is a big difference between a drivable engine that feels fast and strong and one which makes a higher number on a dyno.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
