  • Replies 580
Just thought I'd add to the list - Looks like I am playing the waiting game.
I 'won' at an auction on saturday. 89 gtst 4 door, silver. I am not 100% on the details yet, my importer is getting back to me today with that and high quality pics.
He ships on Kiwi tho, and is gonna truck it down from QLD to Sydney.
I will keep ya's informed of my progress (and no doubt pics when i get them - in a different thread of course)
Has anyone considered shipping in a container? I know it is a bit more expensive (not so expensive if you share one) but it takes out the uncertainty of missing more boats. As there is only one boat to fremantle each month I am very tempted to go the container option asap. Has anyone had any experience with shipping there cars in containers?
I have been given this option for an extra $600 + moving the car to a location where it can be shipped in a container however I've decided to wait for about 3 weeks to see if a ship becomes available.
Remember Tyler - the things we own end up owning us :P
Just talked to my guy. He seems confident (wouldnt garuntee of course) that he could land mine on january 10?12? sorry i forgot... which i would imagine is the next kiwi....
i will let u's know :P
You will have to be very lucky to make the next kiwi boat. It has already started loading... cross your fingers mate, but if you do it will most likely set a record in time bought to time on boat!
Richard
Well boys, a little update on my progress:
I've just sent of a fax to engage the services of a customs agent in QLD. I've organised road freight from Brisbane down to Sydney, and I've sent off my request for an exemption to import a car pre-charged with R12. Car should be loaded tomorrow, and I'll hopefully have my BL by the end of the week. Then I'll send it to my CA, and hopefully when I get back from Japan my car will be parked in the garage at home.
Richard
Richard
I guess I'd like to see how someone that paid for their 1990 GTR in 2005 goes.
here's hoping richard
so has anyone had confirmation for there car on the ship on the 20th yet?
I got told they won't know till boxing day! god damn it. I am getting really sad over this. I don't know if importing a car was worth it.
should have just bought one that was here for a few k more
mark
Depending on which port your car was at it may not be loaded until 24th December. Prince no.1 is loading between 20-24 December at various ports in Japan. Mine will be loaded tomorrow so I should know on Friday that it's on the water. The loading dates go: Funabashi (20-21st), Kawasaki (22nd), Nagoya (23rd) and Osaka (24th). it makes me think that those with cars in Osaka or Nagoya may have less chance of getting on if there are lots of cars waiting at the first two ports. I'm sure we'll all be ok though.
Yeah, when you realise that you can buy a decent BNR32 GTR here for around $25-$30K then it doesn't seem that cheap does it? My car will probably cost that much, and I don't even know for sure yet if it's any good. Oh, well we made our choice knowing the risks. When the car is here I'll be all smiles. No point in worrying about it now :)
Richard
well, my car is stuck waiting to be released from port in brisbane, and then it's on a truck and down to vic.
unfortunantly it wont be here b4 xmas, but hopefully i'll have it before the end of the month - depending on how things go.
If anyone is interested, here is what i've paid so far (my car was shipped on a container ship as RORO cargo - which was a bit more expensive than standard RORO).
$4000 Cost of Car
$ 200 Port Transfer Within Japan
$1018 Shipping Japan->Brizzy
$1186 Customs Duty & GST
$ 308 Transport to Melbourne
$ 660 Customs Fees, Quarantine charges, Other random fees etc.
$7372
anyone here have a car coming from Kyushu? From what I saw on a map is the Japanese equivalent of Tasmania :(
yeah, apparantly that's where mine is.
Ben at J_Spec has recommended paying to get it moved to Osaka as it will have a better chance of getting on a boat. Still not guaranteed but at least better chances.
should cost about $350
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
