r33 gtst
hks 2835 pro s kit, stock exh manifoid
550 cc nismos
z32 AFM
apexi pfc + boost control kit
K&N airfilter in stock airbox
4'' cat 3'' exh
no oil catch can
341.9 rwhp or 255 rwkw @ 19 psi boost
gcg gt30 500hp turbo with rb25 a/r.63 exhaust housing, low mount exhaust manifold, step 1 tomei pon cams, match ported head, wiseco forged pistons 8.5 to 1 comp, gtr conrods, ces twin dump pipe, 4inch magic cat , 3inch exhaust. link ecu , 550cc injectors, 650mmx300mmx80mm intercooler. optimax extreme 100 ron fuel. 245rwkws on 14psi and 281rwkws on 21psi. old shootout graph in members gallery , will post new graph when i get a chance. cheers . oh yeah bmc 4inch pod filter- think that covers it!
RB25DET Series II
Stock set up with APEXi Filter and "replacement" 2.5" exhaust I made 220 RWHP (164 RWKW). With the addition of the AEM EMS, I made 245 RWHP (183 RWKW). Dyno Graph Below. Both runs were at the stock 8 psig boost level.
I then added an APEXi N1 Cat Back, and a 3" stright thru cat delete, 4" intercooler, and a Greddy Intake Manifold. The results are 310 RWHP (231 RWKW) at the same 8 psig. We tried to up the boost, but it would only go to 10 psig at 6200, then it bled back to 8 psig by 7K. The turbo is pretty much done. On this dyno pull, I made 250 RWTQ (34.6 KG-M) from 3000 to redline.
Dynoed My car on the 22/1/2006.
Car is a R33 GTS-T
Mods:
3" Turbo Back Exhaust
Blitz FMIC
HKS Pod
12 PSI Boost
Made 247.4HP (184.49Kw)
Got it Dyno tuned today at Unigroup Engineering.
Mods:
Blitz FMIC
HKS Pod
SAFC
11 PSI Boost
Made 206.6kw ( 277.06 Hp)
Did a really good job on the tune
THANKS GUYS!
btw, the first power run was when the safc was installed and just all over the place so take no notice of that (obviously the squiggly line one).
AFRs were 12.4 dropping to 12 at higher rpms.
201 rear wheel kW on shootout mode @35 degrees by Just Engine Management
R33 GTS-t 1995 M spec series 1
turbo: MTQ highflowed turbo
ECU: apexi power fc
exhaust: 3inch turbo back + hi flow cat
intercooler: trust fmic
pump: walbro fuel pump
boost: ran 10psi on blitz dual sbc
air filter: trust pod
clutch: sports carbon clutch
HKS SSQ BOV
Car was lacking a Z-32 afm, and coils showed hot spots as we tryed tuning at 15psi, but had a lot of splattering. Tuner was happy with 201rwkW at 10psi.
good thread. some interesting results. thought i'd post.
R33 gts-t s1
rebuilt motor(approx 20000km ago)
fully balanced bottom end
arc forged pistons(safe power)
tomei 1.5mm metal head gasket
stock turbo @ 1bar(upgrading very soon)
3" turbo back exhaust with cat
k&n podfilter
blitz fmic
sequential bov
turbosmart e-boost2@ 9,12 & 14.4psi(excellent boost controller. highly recommend)
power fc(just installed)
tuned by morpowa in sa(enclosed dyno with air con & exhaust extraction. very experienced)
213.7rwkw@1bar
need new fuel pump, injectors(running 97% duty at the moment) and of course turbo
aiming for 280-300rwkw. should be no problem
p.s. post graph soon
1998 Skyline R34 GT-T (Tiptronic)
Custom T04e Hi-Flow Turbo
Nismo Fuel Pressure Regulator
Bosch 040 Fuel Pump
A'PEXi Pod Filter
Trust Cat-Back Exhaust (PEii) 3"
Hybrid Copy FMIC
NGK Iridium Spark Plugs (1.1mm)
Hybrid Dual-Stage EBC
SAFC2 D1 Limited Edition
Tuned using BP Ultimate (98RON) @ 11psi.
This was the absolute max we could drain out of the car during the dyno tuning at Hitman - Injection Tuning. The SAFC2 and stock ECU combination was limiting our numbers through the protection systems (fuel cut, rich and retard etc.)
However, full boost was reached at 1,800rpm (11psi) and we got 198.2rwkw at the end of the day. Considering we achieved this without a full exhaust :lol: I'd say this was one farkin' good upgrade setup.
Next thing is to finish the exhaust with a 3" Front/Dump Pipe and 4" Hi-Flow Cat, get bigger injectors (Nismo 480cc) and a new ECU (thinking Haltech e11v2 or HKS F-Con Is).
Then we will be shooting for 240rwkw to 280rwkw depending on how my gearbox likes it :) But that's ok, there's a new box being designed right now for my car :D
see latest turbo compare graph.
if you want your dyno run / turbo combo on it please send me a pm
please make sure if you do you have a dyno sheet in 4th gear and its an r33 rb25
and the turbo combo is not already on the compare sheeet.
thanks
the gt25 stock is my r33 with all the basid mods with stock turbo
  • Like 1
1995 s1.5 gts-t
PFC
FMIC
TURBO BACK EXHAUST
UNKNOWN SPEC TURBO PROB 450-500HP RATED BUT A LIL INEFFICENT.
CUSCO DIFF
BLITZ DSBC
POD FILTER
VEE PORT BOV
LARGER INJECTORS
REST IS STANDARD
224RWKW @18PSI AND MORE TO COME!
89 R31 Passage GT
Rb25DET
Injectors???
Power FC
z32AFM
Walbro 800
3in zorst from Turbo
KKR 480 Turbo
Custom IC with piping
Custom Air intake and Pod
297rwkws on 16psi
Edited by GT-PASSAGE
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
