Hi!
R33gtst
just jap fmic
unifilter pod and airbox
3 inch dump and cat back
turbo smart single stage boost controller
12psi
hks fuel cut defender
195.3rwkw
stock turbo,injectors and fuel pump
dyno graph to come :happy:
big cheers to the guys at UAS - awesome work :(
Hi All,
I have a R32 with RB25DET with the following mods:
R33GTR FMIC
Full 3 inch exhaust and hi flow cat
HKS 2535 turbo
Wolf 3D engine management system
Upgraded injectors
Pod
Upgraded Fuel Pump
Its first dyno was on 12psi for 230rwkw, with the fuel leaning out, so am replacing the fuel pump and winding up the boost to 17psi. I will post results later on in the week when the work is done and the final dyno is run.
Silva32
:sorcerer:
r33 GTST
Remapped Nerve Essential ECU
HKS 2530
Splitfire coils
4" Magic Cat apexi exhaust
HKS pod
FMIC
Stock injectors
Stock Reg (will be up grading)
Stock Pump (will be up grading)
18psi
Edited by race_snooze
R33 S1 Manual
Stock bottem end and head
stock turbo
stock plenum
stock injectors
stock ecu
500hp tomeii fuel pump
3" dump to a big body high flow BOS cat
trust pe II cat back
gtr intercooler with some dodgey piping
metal intake pipe
apexi pod
catch can
turbosmart dual stage boost controller set to 11psi
209.5rwkw
new mods:
Greddy Profec B Spec II set to 11.15psi
future mods:
centre muffler taken out
slide r33 highflow
550cc injectors or gtr injectors
apexi pfc
im hoping somewhere over 235rwkw.
anyone know of good injectors GTR size or over that are straight drop in on rb25det? thanks
Edited by LTHLRB
Car: R33 GTST Series 1.5
Mods:
Walbrow GSS342 pump
Adjustable fuel reg
FMIC from CRD
Flyen 3' dump and 3' exhaust all the way through
$22 boost controller (spiking like crazy)
HKS Pod and intake
Stock Internals
Stock Turbo
managed [email protected] psi
the controller was spiking bigtime and then dropping off so it looks like time for a new controller, something good. The car pulls ok, but then hits a down spot and then takes off again. Goign to talk to the tuner see what we can do.
http://www.skylinesaustralia.com/forums/in...howtopic=137100
Update on the RBZ. Went back on the dyno last night and did some more tuning and sprayed some nitrous to it. Laid down 595 rwhp (~444 kw) on 93 octane. Still internally stock motor.....stock headgasket, cams, and everything. AFR around 11.2:1
JT
Stock turbo, hi-flowed
Trust Type M intercooler and piping
Apexi Power FC
Apexi AVCR Boost Controller
Split engine and dump from Hi Tech Mufflers (3.5"), racing cat (5"), HKS Super Drager catback (3.5")
Bosch 044 fuel pump
Sard Fuel Pressure Regulator
Pod filter
Splitfire coil packs
238.5kw at the wheels at 14 pound
Tuned at CRD - they are the bomb!
R33 GTS-T
Hi-flow Turbo
Apexi PowerFc + HC
Trust Turbo Back Exhaust + Split Dump
Bleed Valve Boost Controller set to 10Psi
ARC Sidemount Intercooler
Pod Filter + Cold Air Box
Made 281.4rwhp
The intercooler became a restriction at 280 rwhp so it was very safely and economically tuned at that point. Will upgrade intercooler at a later date and wind some more timing + boost into it.
Special thanks to Paul & Michael who tuned my car at Elite Automotive in Archerfield. I highly recommend Elite they are very good at what they do and fantastic to deal with. So if you in the area and want a good tune done they tune various ecu's so give Paul a call :laugh:..
If anyone has any questions please feel free to ask ill try get a photo of the dyno sheet up asap.
Edited by fEkuaR
Nissan R33 Series 1 GTS25T
3" Turbo back exhaust to twin 2.5" pipes
Apexi CAI
Bleed valve
JustJap FMIC
pulled 160rwkw on 4.5 - 5psi with huge misfiring problems. more boost + new sparks and a safc should solve this problem and hopefully be reaching ~ 200rwkw.
  • 3 weeks later...
1994 GTST S1
1st Setup
Stock everything except for
e-manage
040 Fuel Pump
Stock boost
HKS super dragger zorst
168.8rwkw
2nd Setup
Custom Turbo setup- small, 1-1.3bar at 3k - yipieee
Apexi Dump Pipe
VG30 AFM
Spitfire Coil Packs
730CFM Hi-Flow cat
Unifilter POD and cover
Emanage
Bleed valve
257.1 rwkw @1.1bar
3rd Setup
As second plus
AVCR
PowerFC
SARD 550cc injectors
Twin plate clutch
HKS Adj Cam gears
272rw KW
r33camgears.pdf
It's go live time. Thanks to the testers for giving the site a good shakedown over the last week.
Dyno Site
A few "rules" need to be followed:
1. Do not enter junk data. You can still view other people's graphs even if you don't have one of your own.
2. Do not sign up with crap details. If I see any dodgy logins created I will delete them, the car(s) and the dyno runs associated with those logins.
3. Do not forget your password. The password is encrypted in the database so I can't tell you what it is, and I haven't created myself a password reset page yet.
4. Report bugs to my email (zilla34 at gmail.com) with username and screen shots where possible.
5. Add suggestions for future enhancements in this thread.
Keep in mind, if this site gets abused I will pull it down.
Suggestions:
1. Sign up with the same username you have on SAU.
2. Add dyno type, location and shootout mode to dyno descriptions.
If there are any graphic designers who want to do some screen layout concepts send them to my email and I'll look at making it look pretty for version 2.0.
Willo.
Here's the page for entering your dyno data to compare it to other users.
http://sau.garagespank.com/login.php
And here's the url for talking about it, things which could be improved, results, problems etc.
http://www.skylinesaustralia.com/forums/in...howtopic=126563
way cool man...will add some details later
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
