series 2 rb25det (in an s13)
hypergear tr43
s15 injectors
fmic
3" straight through exhaust
bosch 040
microtech lt12s
with dodgy boost controller:
with good boost controller and 7psi actuator:
with good boost controller and 12psi actuator:
well well well.
I brought a r32 bout 4 weeks ago.
I got it for 4 grand with 3 months rego on it. The car has a rb25det fitted upgraded clutch
FMIC
3'' exhaust Turbo back
and 10 psi boost.
It now has a malpassi FPR on it
The boost drops off to bout 7.5psi and made 185.5 RWKW
Does this sound right. The car goes like a rocket is wicked to drive. I got it so cheap cos the chick selling it was leaving the country the next day i offered 4k and she took it. Was advertised for 10k.
will post pic of the dyno sheet and the car in the morning.
I personally am wrapped with the power it is making and it is heaps quicker then my rb20det powered s13 which had 165rwkw. Did not think 20 RWKW would makle that much difference.
My RB25 powered 180sx
The motor is stock but i have the following mods
Standard dump/front
3'' exhaust
pod
cooler
catch can
.9bar
apexi afc neo
The tuner said an o2 sensor is dead, which is contributing to the crappy curve. Once that is replaced and i get a boost controller, he said that i should be making near the 270rwhp mark with a proper tune.
Apexi Power FC
hi flowed turbo (450hp)
Turbo back exhaust with Trust PE2 catback
custom made front facing Plenum by CPC (Custum Plenum Creations)
80mm billet throttle body
Tomei 256 cams
550cc sard injectors
Bosch 040 fuel pump
Hybrid GT Spec FMIC
Z32 air flow meter
OS Giken exhaust cam gear
alloy catch can
lightened fly wheel
Apexi pod filter
Front and rear strut brace
Apexi AVCR
252.4rwkw @ 18psi
Edited by R31Nismoid
Just got word from my tuner 450RWHP/335.5RWKW
Has a little more work to do before i can pick it up on Saturday morning....
I'll post a graph as soon as i get it :)
Picked her up this morning... it's pretty wild...
only set on low boost ATM 18psi, Graph is on High on 21psi...
Dyno1.pdf
R32 GTST 4DOOR
RB25 Motor and gearbox conversion
Forged pistons
Standard shot penned rods
ACL race bearings
Balanced and knife edged crank
Cometic head gasket
Rebuilt standard head and valve train
Greddy plenum
Billet fuel rail
580cc injectors
LS1 coil packs
040 external pump modified to fit in tank
malpassi fuel reg
custom 3" alloy intercooler piping
ARE 600x300x75 with modified intanks
Garrett GT35/82R (.82 rear house)
Stainless steel and hpc coated top mount manifold
50mm external gate with screamer (of course)
Full 3.5" exhaust
Wolf V500 computer
Tuned on 22 psi and produced 423.8hp at the rears.
Still at tuners. Picking up hopefully friday.
Tuned by Peter at RPM PERFORMANCE AND DYNO at Morayfield.
Will post graph when i recieve it. :/
UPDATE
Only change, 6boost manifold
Now, 16psi 400hp
19psi 430hp....picked up 30 hp
RB25DET
Tomei 256 8.5mm cams
HKS 3037S ex 0.74 56T
Turbosmart 48mm pro gate.
FMIC
3 inch exhaust Catco cat.
550cc injectors.
standard water/oil pump.
Autronic SM2 with 500R CDI
Autronic boost controller
Low boost 16psi 370rwhp
high boost 19psi 400rwhp
Check out the torque curve.....I mean flat line :D
I've got
RB25DETneo
Front Facing Plenum
GT3540 on standard manifold
HKS Fuel Rail and 680cc injectors
Bosch Motorsports pump (044 or 040 can't remember which is the intank one)
Splitfire Coils
FMIC
3" Titanium Exhaust
Power FC
Got boost control issues at the moment due to internal gate, will be upgrading to external gate and new manifold.
Currently boost starts at 12psi and ramps up to and holds 19psi, it was up to 337rwkw at one stage but the boost kept on climbing way past 20psi.
r34 gtt 1998
Vortex 98
splitfires
apexi pod
walbro fuel pump
greddy boost contoller
3" split front dump pipe
catco cat
3" nismo exhaust
nistune chip
running on 12psi
213rwkw
R32 with rb25
Splitfires
Front mount
Stage 1 high flow turbo from Precision
Gizmo IBC
CES split dump/front pipe
Apexi Pod
Walbro Pump and Fuel Pres Reg
Power FC
218rwkw at 12psi
taking it to willowbank on wed for a 1/4 mile time
  • 3 weeks later...
STD RB25
Tiny HKS FMIC
STD Injectors @ 75psi base fuel pressure
Z32 AFM
TD06L2-20G Chinese Copy
261 rwkw @ 16 psi - Couldn't get any more fuel pressure into it :D
New injectors are on the way, and no I wouldn't ever recommend that much fuel pressure to anyone!
96 r33 gtst series 2
Nismo fuel pump
Nismo 555cc injectors
FMIC
z32 afm
HKS 3.5" > 4" straight through exhaust with split dump
HKS GT-RS
HKS actuator and turbotech manual boost controller
HKS pod
Splitfires
PowerFC
330hp at about 17psi using 98
1996 Series 2 R33 m-spec
Garrett GT3076 turbo, 6 Boost Top mount manifold, 48mm turbosmart wastegate, custom dump/front/screamer pipe, HKS Super Drager 3.5" cat back exhaust, Front Mount, GReddy Inlet Plenum, Nismo 740cc Injectors, Bosch Fuel Pump.
apparently would've got just over 400 atw, if i has a decent cat, rather than the stock one.
oh and im using a power fc and blitz 4 channel boost controller
Edited by ryansr33
Standard ecu
Standard afm
Standard injectors
Standard fuel pump
Standard air box with k&n filter
3" exhaust with x-force hi flow cat
blitz return piping fmic
vg30 exhaust housing and center with rb25 comp cover bored out to fit a to4b v-trim comp wheel THREAD ON THE R&D FOR THIS TURBO
223 rwkw @14PSI
Edited by W0rp3D
RB25DET Unopened
HKS 3037 Pro S Turbo kit
Standard airbox with K&N Filter
Z32 AFM
555 Nismo injectors
Nismo Fuel Pump
Power FC
Gizzmo EBC
Blitz LM cooler
251rwkw @ 15psi
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
