Series 2 RB25DET
Engine recently rebuilt with Aries Pistons 20 thou over, cometic head gasket and head rebuilt... etc
ECU -Microtech
Hi-flowed Turbo TO4E by Fred @ Turbolic
Blitz blow-off valve
HKS Ram Filter in Polished Box
Sard fuel regulator with gauge
Walbro Fuel pump
Profec B Boost controller
Custom inlet plenum,
Custom PWR intercooler and plumbing
Aftermarket 80mm throttle body
3" dump pipe, 3.5" cat and 3" exhaust
Splifire DI coils
With these mods and tuned by Adam @ JEM netted 229rwkw @~ 6200RPM (factory ~147kw)- very nice :D power from down low
Issues with backpressure and compressor surge limited boost being raise above 16psig dropping down to 14 ;) . Once sorted will raise boost to 20psi.
STD RB25
Tiny HKS FMIC
STD Injectors @ 75psi base fuel pressure
Z32 AFM
TD06L2-20G Chinese Copy
261 rwkw @ 16 psi - Couldn't get any more fuel pressure into it :P
New injectors are on the way, and no I wouldn't ever recommend that much fuel pressure to anyone!
Retuned last night more mods:
GReddy Copy Plenum
Infinity 90mm Throttle Body
2:1 Rising Rate Reg
Dual Boost Controllers - One for each port on Gate
305 rwkw @ 25 psi dropping to 18 psi..
700x300x100 FMIC
1996 Series 2 R33 gts-t
-Power FC
-Stock turbo
- Full 3" Exhaust, Split dump and Cat
-Drift Pod
-Iridium Spark Plugs
-Greddy FMIC
-Greddy Profec B Spec II
-Tomei Fuel Pump
-Exedy Racing Clutch
-Bp Ultimate
Everything else stock
First tune without the Boost Controller
-Made 200.8kw at the wheels on ~10 psi
Final Tune with Greddy EBC
-Low Boost @ 192kw at the wheels on ~12 psi
-High Boost @ 220.3kw at the wheels on ~14 psi
Edited by Spraderz-33
1998 R33 GTST Series 2
Stock turbo + injectors (80%)
Walboro Fuel pump, Sard fuel pressure reg, pod, Hybrid HDi FMIC, full exhaust + dump
ViPEC ecu + boost control
13psi - 244 HP
9psi - 214 HP
safe tune, still seems a little low tho
R33 Series 1, RB25det manual, Power FC, FMIC, Full Exhaust System from turbo back with high flow cat, Walbro 550hp Fuel Pump, K&N Filter, Splitfire Coilpacks, NGK Platinum Plugs(0.8). Made 256rwhp on a safe tune on 98RON BP Pump Fuel.
Recently Purchased T04e/T3 Highflowed Turbo, Nismo 550cc injectors, Stainless Low Mount Manifold. Hoping for the 340-380rwhp, depending on safety on engine internals and gearbox.
Got mine retuned this week.
R32 with rb25det series 1.
Stock turbo
FMIC
Sard FPR
Walbro 255L
Bleed tap boost controller
Microtech lt10s
Stock injectors
Remote wasted spark coil setup
Full 3'' exhaust from the turbo back
Made 254.8 hp @ 10psi bleeding back to 8psi
Still has more tuning to do as we realised that Microtech did not add the tuning program for the VCT so we cant turn it on and off. Will make more usable power when this is fixed next week and my tuner has said we will boost it to 12psi and add some more timing etc.
Hoping for around 270hp on 12psi with finer tuning.
Will keep you all updated
my car hasnt been tuned properly yet cos of boost issues but this is how it went...
stock cams
cp pistons 20 thou oversize
gready copy manifold
80mm throttle body
are cooler
800 cc sard injectors
tomie 700 hp fuel pump
high mount gt35r 84 rear
50 turbosmart wastegate
3.5 insh exaust
microtech lt8 + ignition module
6 bosh coilpacks
1.2 hks head gasket
port and polish decompressed head
shot peened rods + arp rod bolts
balanced
n1 oil pump
car over boost because of shit exaust manifold wich i am changing.. tuner backed off at 25 psi 6500rpm 400hp
i expected more but i will post again in a few weeks wit new manifold tomie pon cams and ajustable exhaust. hope fully have a dyno sheet to put up for ya's and 500 hp i hope
1994 r33 skyline
.Stock Internals
.Some kind of cams came with the car
.Splitfire Coils
.Walbro Fuel pump
.Metal intake from turbo
.Stock turbo
.Pod filter
.Nismo Catback exhaust
.Stock side mount cooler
Car running at 7pounds boost as it from factory suprisingly i pulled
188.9rwkw at Creatd motorsport on a dyno dynamics dyno
VERY HAPPY
r33 s1 rb25det.
t04e garret turbo
high mount manifold
3 inch dump with 3 1/2 inch exaust
38mm ext. gate
microtech lt-12s
greddy profec b spec II ebc
hks front mount intercooler
JJR coilpacks
exedy heavy duty clutch
oil catch can
blitz air filter
just got her back at 249.3rwkw at 14.5 ( 1 bar) of boost
and 990.2 nm of torque
ITS NOT HARD TO BELIEVE BUDDY WE HAD 5 RUNS AND ALL SIMILAIR AND ITS ON A DYNO DYNAMICS DYNO NOT SOME DODGY ONE APPARANTLY MY ENGINES VERY HEALTHY AND STRONG COMPARED TO SOME SKYLINES OUT THERE CLICK ON THE LINK YOU CAN SEE THA DYNO READ OUT :ninja:
http://viewmorepics.myspace.com/index.cfm?...7d-a9dccc665e70
Nismo thermostate
Nismo high flow fuel pump
sard 850cc injectors
Nismo flywheel
Excedy custom clutch
Eagle conrods
ARP head studs
Arias pistons & rings
Acl engine bearings
Sard fuel regulator
Nissan N1 oil pump
Apex power FC
Greddy boost controller
Greddy blow off valve
Greddy intake plenum
Catco stainless high flow cat converter
hks 3-3.75 inch exhaust
hpi split dump pipe
Splitfire coil packs
Front mount intercooler
Arc air box & cold air duct
HKS valve springs
HKS cam shafts 256-intake
HKS cam shafts 264-exhaust
HKS turbo kit 3037 pro s kit
Bosch Z32 air flow meter
40mm radiator
made 303.6kw atw on hi boost
291 kw atw on low boost
now at 309 kw
r33 s1 rb25det.
t04e garret turbo
high mount manifold
38mm ext. gate
microtech lt-12s
JJR coilpacks
oil catch can
blitz air filter
my bad....also denso 550cc injectors, bosche 040 fuel pump :rolleyes::)
p.s......t04e suck big donkey balls...
R33 Skyline SII
PowerFC
Kakimoto catback exhaust
Catco Hi Flo Cat
FLYN Bellmouth Dump/front pipe
Stealth FMIC
Solenoid Bleed Type Boost Controller
K&N Panel Filter
All else is stock
Getting 189.5kw at the treads with 13psi.
Tuner mentioned I could get 210kw with a wolf3d??
Edited by EeLeYe
^^^ I would agree with that tuner as i have been told the same put the microtech on and hey presto.
Stock turbo
FMIC
Sard FPR
Walbro 255L
Microtech lt10s
Stock injectors
An Update i got it back today with boost to 12psi bleeding back to 10psi made 203.6rwkw. Stuffing with the wastegate this weekend and wil get it to hold 12psi and hoping for the 210rwkw mark.
Hey guys just got my tune done fell short of my 300hp atw goal!!
1995 Nissan Skyline GTS - with rb25det conversion - KKR480 Turbo, Otomoto Dump Pipe, Nismo Stainless Front pipe, 3" stainless cat-back, Nismo 740cc injectors,apexi dual pannel D1 forced pod filter, apexi PFC, greddy intake manifold, greddy TB adaptor, greddy typre RS bov, greddy oil catch can, Hybrid FMIC, walbro intake 500hp pump..
Got it tuned at 10psi with rev limiter set @ 7000rpm and got 192.6kw atw.
Hame
RB25DET Unopened
HKS 3037 Pro S Turbo kit
Standard airbox with K&N Filter
Z32 AFM
555 Nismo injectors
Nismo Fuel Pump
Power FC
Gizzmo EBC
Blitz LM cooler
251rwkw @ 15psi
Now with new tune and running 18psi
273.9rwkw
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
