1995 R33 series 1.5
PWR front mount
sPlit fire coil packs
stock boost
stock turbo
iridium plugs
lighten fly wheel
auto diff I think higher ratio
pod filter
98 octane pump fuel
stock fuel pump
stock internals
full 3" exhaust Welded turbo back
dyno about 2 months ago 245HP 183KW
Very happy on stock boost
Soon SAFC to be tuned and boosted to 10psi hoping to make it over the 200KW mark :)
Edited by simonyoungr33
1997 R33 GTSt:
Head:
HKS 256, 264 cams
Tomei valve springs
Brand new OEM valves
Brand new OEM guides
COMETIC 1.3mm Headgasket
Bottom End:
Mahle pistons
SPOOL rods
ACL Race beaings
ARP Mains and Rod bolts
Intake:
4inch HPI pod filter
Custom 4inch intake pipe
Tube and Fin intercooler kit
Greddy plenum
Fuel:
Nismo fuel pump
Nismo 740cc injectors
Turbo and Exhaust:
Garrett GT3067.82
6BOOST manifold
Synchronic 50mm wastegate (off turbo housing)
Custom dump pipe
Fujitsubo exhaust
Ignition:
Splitfire coilpacks
ECU:
Haltech E11V2
Tuned on E85 bleeding down to 16psi.
325rwkw
RB25 NEO
VG30 Highflow Turbo
3" exhaust with "highflow" cat
Z32 AFM
Sard 550CC injectors
HKS Adjustable Cam Gear
Power FC (tuned by Paul @ Chasers)
Blitz SBC-iD3 Boost Controller
223rwkw on 12.5psi (bleed down to 12psi)
247rwkw on 15psi (bleed down to 14psi)
it made ~270rwkw on 18psi, but i need to go and get the printout for it
1993 r33 gts-t skyline auto
kkr480 internal wastgate turbo
stainless steel low mount manifold
full 3 inch exhaust
turbosmart manual boost controller
turbosmart dual port BOV
stock intercooler off and toyota supra
walbro 500hp fuel pump
stock injectors and fuel pressure reg
r32 ecu remapped
z32 air flow meter
acl race series 1.3mm stainless steel head gasket
splitfire coilpack
stage 2 shift kit from mv automotive
ran at 20psi made 226.4RWKW
Edited by nathan0511
R34 gtt neo manual
Stock ecu
Stock turbo
Hks Hi Silent ss cat back 3"
X force Hi flow ss cat 3"
JJR 3" ss dump
Prof spec b boost controller 10psi low set 11psi hi set
Fmic
apexi pod
Shell V power
212.3 awkw (on hi boost setting)
dyno'd at ultimotive (Phill great bloke)
cheers
1989 C33 Laurel
S1 R33 RB25DET
Apex'i RC6 Turbo
Apex'i Steampipe high mount manifold
38mm External Gate
Apex'i power FC
Hiflowed injectors 550cc
3 inch dump with straight pipe
HKS death pod
Walbro 255l/hr fuel pump
246.8rwkw @ 16psi on turbo tune's dyno
1997 R33 GTSt:
Head:
HKS 256, 264 cams
Tomei valve springs
Bottom End:
Mahle pistons
SPOOL rods
ACL Race beaings
Intake:
Greddy plenum
Fuel:
Nismo fuel pump
Turbo and Exhaust:
Garrett GT3067.82
6BOOST manifold
Custom dump pipe
Fujitsubo exhaust
Ignition:
Splitfire coilpacks
ECU:
Haltech E11V2
325rwkw
UPDATE
HKS 3.75inch exhaust
Another tune with a touch more boost.
Still have the bleed problem but its better than before.
Standard motor other than forged pistons.
-Wolf 3d V4 tuned by C&V
-15Psi
-Optimax 98
-Machined standard turbo with larger compressor and exhaust wheel built by Precision TurboChargers.
-Just Jap FMIC
-Just Jap single dump pipe, unknown cat back 3"
-K&N pod
-500hp fuel pump
251 RWKW, nice smooth power curve
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
