Stock Internals
110000+kms
BP 98
HKS GT-RS turbo
Tomei 555cc injectors
X-Force 3" turbo back exhaust
Apexi PFC
Apexi Super Suction intake kit
Z32 AFM
Blitz LM FMIC
Greddy ProfecB SpecII
Splitfire coil packs
Walbro 255lph fuel pump
(see signature for full details)
An "honest" 244rwkw @ 18psi on a nice "safe" tune :banana:
Got my car re tuned at Initial D Racing. MASSIVE difference compared to the last tune done at CREATD Motorsports.. Car supposibly made 297kw on 18psi. Ended up making 270kw on another dyno with the afr at 14.5 and climbing.
So the afr has been beefed up and is now at 11.0. @ 18psi it makes 300kw on the knocker with full boost in 3rd gear at 3000 - 3500 rpm.
Externally gates 3076 .82 Turbo.
Tial 44mm gate.
Greddy Profec B boost controller.
JJR Ex Cam Gear.
Apexi pfc w/ z32 afm.
Highflowed injecters soon to be changed to nismo 740cc units.
Std head and bottem end.
Future mods will be New injectors, 044 and Surge tank. FULL RACE type ex manifold and new dump pipe.
Edited by LTHLRB
95 model R33 GTST with 165,000KM stock motor
High flowed 650cc injectors
PWR Front mounted cooler
Xforce turbo back exhaust
Manual boost controller
44mm HKS external gate counted to turbine housing
Hypergear SS-2 stockie bolton turbo
Custom made 3inch intake pipe
PFC and Z32 AFM
Pump 98 fuel. Car made 307rwkws on 22psi, 296rwkws on 20psi.
post-31034-0-51015400-1318749957_thumb.jpg post-31034-0-03007300-1318749964_thumb.jpg
Edited by kwickr33
Just got the car back from Croydon Racing Development
Nistune
HKS 550CC Injectors
Bosch Z32 AFM
Walbro Fuel Pump
Boost was set to 16psi (i think a bit too much for the standard turbo.. lol)
Ran 229.7rwkw
Update;
GT3076 (i think .62)
Made 271rwkw, before cltuch slipped and it wasn't holding boost.
Getting a Exedy heavy duty clutch and a Greddy profec b spec 2, once done will upload results.
R34
Stock motor
3inch from the turbo back
Hyflow turbo
Pod filter
An nistune
206rwkw @9psi
Afm maxed out an injectors at 80%
forgot to get print out
Done at high power racing
They did a pretty good job :)
R33 rb25
ARP studs
oil system minor mods
3076 .82
tial mv-r
vipec pnp
custom top mount
256 cams
autobahn 88 plenum
OS twin
supporting fuel blah blah you know the drill
430whp@~18 psi 91 octane pump gas
460whp@~20 psi with 40/60 mix of ms109 and 91 octane
I have done a whack of track days and its been running for two years now. All in the tune.
VIDEO
http://www.youtube.com/watch?v=EdlzkxypdxU
Edited by Zacho
Garrett GTX3071r .82 rear .60 compressor
Nistune
850cc PE injectors
Tomei fuel pump
Z32 AFM pod filter with CAI
splitfires
front mount
custom 3" dump into full kakimoto exhaust
HKS EVC 6 boost controller%3ca%20href=DSC_0524.jpg">
R33 internally stock
Gt3076 internally gated .82
Caltex eflex
310rwkw @ 16psi
320rekw @ 18psi but wouldn't hold. So there is a restriction so need to fix that.
Also turbo is on its way out.
Pretty happy with it :)
R32 Pig
RB25 Stock Internals
Stock cams
Arp Head Studs
Cometic MLS
Jecs 750cc
Stock fuel rail and regulator
Sard fuel pump
Greddy Copy Plenum
Stock TB
Stock coilpacks (s2)
Power FC
98 Ron
GT3071R
Tial 38mm to screamer
China exhaust manifold
China intercooler
Engine rebuilt by myself
~300rwkw (400rwhp) @ 18psi C-red perth dyno dynamics
Lowered the rev limiter to 6700rpm so I can safely rev on track.
Edited by kliono
R34 GTT
Hiflow turbo
Hks dump pipe
Turnflow front mount
K&N Pod
Walbro fuel pump
3"exhaust
Nistune
Tuned by chasers eastside
Made 222.2kw on 13psi up to 6500rpm then drops to 10psi
Very happy with the result.
180sx
RB25 S2
Greddy Plenum
Q45 Throttle body
1000cc injectors
top mount rail
turbosmart 1200 fpr
walbro pump(unsafe level / now upgrading)
Steam pipe manifold
GTX3706 0.82 Tial rear
Tial MVR 44 gate
z32 afm(pressure side)
z32 Nistune ECU
Zero internal work done
E85 fuel
DynaPack
car made 396kw but had a redline in place at 7000 once removed
Re-runs proved a consistent 394kw
Standard s2 motor
Splitfire coilpacks
Plazmaman plenum and 80mm throttle body
660cc injectors and some fancy ass rail
Walbro pump
3.5 inch exhaust
Front mount
Td06 20g fiddled with ;)
44mm tial ext gate
Adaptronic ecu
Bcpr7es plugs capped .6
Sard Reg
380rwhp on 18psi
Tuned by micks motorsport
1998 R34 GTT
Standard Neo Motor
Standard Turbo
Standard Injectors
Standard Coilpacks
Bosch 040 Fuel Pump
FMIC
3.5 inch turbo back Exhaust
Blitz Boost Controller
Nistune ECU
210rwkw on 10psi
Tuned by Paul @ Chasers West Melbourne. Pretty happy! Awesome tune. Fixed all driveability and fuel consumption issues!
2000 model R34 GTT
nistune ecu
fmic
3 inch turbo back exhaust..
boosted to 17psi
221kw atw..with a slipping clutch
that was 2-3 years ago... turbo is now on its last legs... upgrade time!!
Been playing around with the car of late.
previously had
269@ 18psi falling off to 16 (263 run printed)
Nismo 555 injectors
greddy profec b
Garrett 3076 52t .82 internally gated 1 bar actuator
Tomei Poncams
98 octane
usual front mount and 3" exhaust
z32 afm
changes
3076 52t with .63 rear
Tial 44mm external gate
made 236 @ 15psi falling to 14 (no boost control other than the spring in the gate)
*there was no tune done with the new rear set up due to going e85 in the next month or so
verdict
boost comes on a LOT earlier, but no issues with traction. I do miss the power in the top end though, really punches coming out of corners.
plans
E85 + 18psi + 740cc injectors should see me back around the 270ish mark and be back to being awesome with great response. anything more and it does start to become unusable. when the car was making 270 it was great on track, but really lacked low end pull
also worth noting a few friends have the 56t version with identical set ups, the 52t has no where near the high pitched spool noise as the 56t, it does try though
RB25DET with standard internals
Highflowed turbo
3" exhaust with high flow cat
FMIC
Splitfire coilpacks
Power FC
Made 246rwkw on 16psi and drops back to 15psi. Tuned by Danny B
At Initial D Racing. Very happy with the result, next upgrade injectors, z32 afm, turbo.
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
550cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
ATR43SS3 prototype turbo
4inch intake pipe
Nistune
Z32 AFM in cooler piping
Pump 98 fuel. Car maxed 325rwkws
Forgot to post this up in here as well...
'98 R34 GT with RB25DET Neo.
660cc Power Enterprise injectors.
Walbro 550hp fuel pump.
600x300x100 FMIC.
Custom 3" turbo-back exhaust.
Custom 3" stainless steel intake.
Greddy Profec B-Spec II.
NIStune.
Z32 AFM.
Hypergear ATR43 FNT G3.
Turbosmart Compgate 40 external wastegate with two 7psi springs.
Tuned to run at 18psi, so still has a bit more in it.
Edited by Hanaldo
