PowerFC ECUs w/ Hand Controllers (NEW & under $1000!)
Adrian,
There is no need to post such inflammatory statements. If Customs chooses to impose GST, it will have to be payed, at least that's my understanding.
I have had a lot of parcels from overseas. Sometimes customs just lets them through, othertimes they decide to charge duties (and this is with parcels properly declared too). Go figure.
Lucien.
  • Replies 247
AP engineering version? hope this dosent apply to me
i got a R32 GTS-T and if i can get one definately put me down for one at that price.
I'd be down for that too
It is the law that GST will have to be paid. But by sending them to individual addresses usually they go straight to your door without any hassle.
Come on lwells, this is openly suggesting that when they are sent to individual addresses, you can avoid the GST.
Open your eyes mate.
Adrian
well, no, you don't have to pay GST on an item purchased overseas... as the service takes place overseas. The only time you'd have to pay GST is if you paid Duty at the customs, because you'd be paying GST on the duty... kapish? Its the whole tax on a tax thing... old news.
Awesome price guys. If anyone is only interested in the Power FC, I am in the market for just a Hand Controller. We might be able to work out a deal. PM me if anyone is interested.
Just as a suggestion, it might be wise to look into the possibility of depositing the $$ into a holding account which only gets released to the seller when the goods are received.
20k is a bit of money.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
