Hi all,
just wondering if I could get some feedback from those in the know.
I am currently a fairly regular attendee at sprint days and am currently pushing my R33 GTR pretty hard and am wanting to go to the next level - ie: more horsepower / side by side stuff and perhaps getting into one of the improved production classes. Rather than keep upgrading the GTR I am looking to buy and set up a dedicated race car and have a couple of options.
1. Buy a GTS (GTST), and install a GTR motor big brakes, etc. etc
2. Buy a R32 GTR and set it up specifically for the track.
I am told the better option is the GTS (with a GTR motor) due to weight, however I don't know whether or not I will miss the 4WD aspect of the GTR's.
Your comments would be appreciated. I want to do as much research before committing as I would like to be spending the money as wisely as possible.
Thanks
https://www.sau.com.au/forums/topic/56269-gtr-or-gts-for-dedicated-race-car/
If its improved production you want, either could be a goer but I would vote for r32. If I understand the regs properly there would be no problems with you running an rb31dett, in a much lighter car than the gtr. Of course there is a traction problem because of the narrow tyres (stock width only), thats the main down side.
However, Improved Production is extremely expensive to be competitive, not as bad as sports sedans but still pricey.
We went for Series 3E (production cars) instead because 1) you can't spend as much and 2) its the same spec for targa cars :P
But I 1000% suggest buying a seperate track car if you are even semi serious. No point wearing out a good, heavy $40,000 road car at the race track.
An Rb31DETT in an gtst would be under $20k to import and build :D
I am probably wrong but isn't a GTR built for racing.
From what I've seen an R32 GTR ate other cars for breakfast during Class A racing back in the day.
I would suggest the GTR as you can prob push harder and I'd say much more fun, plus you can see the look on the faces of others as your boost comes on hard on the main straight to take 1st. :P
Just my 1.45 cents
-JJ
Its all about the money... like others are saying. Of course the GTR would be the advantage, and I've never really seen a GTS-T do as well as a GTR.
Personally I just recently bought an R32 GTS-T with a view for setting it up with a new engine and setup for track and other fun. I could have maybe just afforded a GTR but what is the point if you can't spend much money, afraid of thrashing the pants off it, or hitting something? Kind of takes the fun out of it, when you can't do what you want to do. I suffered that frustration with my R33 gts-t, and hence why I sold it. I wouldn't be making that same mistake again on say an GTR unless I had too much money to throw around.
I just see it as getting a stock gts-t to do "x", compared to getting a stock gtr to do "x" is just as much as a challenge, and just as much fun, unless you really must have the fastest car out there...
If it is then the choice would be clearly GTR and spend a hell of dollars on it.
Then I'd argue why have the R33 GTR for the street? if its all about prestige, just go and buy a BMW or something and use the GTR for what they're for :P
I would have though you would look at purchasing a Japanese car (direct from Japan) set up for track work with all the mods already done to it. If you want it for racing then there isn’t a compliance issue, and it should be cheaper to get a car someone has already spent the R&D on.
I am not suggesting it would be ready to race straight off of the boat (I am sure it would need a freshen up - suspension and motor) but it could save a fortune on buying the parts here.
With this in mind I am guessing there are VERY limited numbers of cars like this up for sale, so you may have to take the GTSt or GTR based solely on what is available at the time.
Problem is buying a car like that from Japan may not be eligible for any class, of corse you can remove and sell the goodies...but if you have coin and sponsors then go the GTR,
Actually in VIC there is a WRX that is very competitive...outside that its a 600HP Falcon that owns the whole field provided the track isnt hard on tyres...
I was thinking about a '05 Improved Production round or two, but work isnt all that great at the moment so going OS looking for better money instead....after the Dutton of course:)
Hi all,
Thanks
How about a Nissan S14 or S15? You can get them down to around 1100 kg. Power to weight ratio plus proper set up will give you some serious time on the track.
Cheers,
VITZ
I've taken the GTR route and realised I should've just got a gtst and blow out whatever $ to set it up. I have to drive a little "conservative" cause the thought of rebuilding an RB26 scares the sh*t out of me.
I still say a 32 gtst over a S13/14 cause SR20's are a little pricey cause they're in demnd. RB20's are cheap as chips.
Hi all,
Thanks
Hi there my name is (GTR V) and I have just moved to the Gold Coast. I have a track ready R32 GTR in NZ which I was thinking about bringing over here. If you are interested please send me an email to [email protected] and I will email you back with the specs and some photos
1990 Nissan Skyline GT-R
HKS 2540 Turbos
HKS Hard Piping Kit
HKS Forged Pistons
HKS Adjustable 280’ Cams
HKS Blow Off Valves
HKS 100mm Intercooler
HKS Oil Cooler
720cc Injectors
Steel Crankshaft
Steel Laminated Head Gasket
Mines Dump Pipes
Level 3 Head Port
GTR War Link ECU
Link 3 Bar Map Sensor
Apexi AVC-R Boost Controller
BEE-R Tuned Stainless Front Pipe
3 ½” Exhaust with Stainless 5” Tip
Tilton Twin Plate Clutch
RIPS 800 HP Fuel System
RIPS Oil Catch Can
Ron Davis Racing Radiator
Impul 300 kmh Speedo
R33 17” GTR Alloys
265.40.17 Dunlop D01J Racing Tyres
R33 Brembo Calipers & Rotors
Ferodo DS3000 Brake Pads
Braided Brake Hoses
400R Modified Front Bumper
Decamber Kit with Neg 3 degrees
Fire Extinguisher
RJS Racing Harness
Recaro Seats
Dyno’d on hub dyno. 440KW @all 4
GTR V
Hi guys, this subject has a large number of possible arguments. Personanly I think the killer for the GTR's is weight, for example our R32 GTST weighs 1245kgs and the R32 GTR 1558 kgs. The 25% extra weight in a GTR means that in order to go around a corner at the same speed it has to have ~25% more grip, in order to stop as well it has to have ~25% better brakes and in order to accelerate as well it has to have ~25% more power.
So if I have a GTST that has the SAME power, SAME suspension, SAME tyres and SAME brakes it will be faster than a GTR over one lap, maybe even for 2 or 3 laps. But over say 20 laps, and the higher the power output, the more the rear tyres on the GTST start to go away. That's why the GTR was, and always will be, Godzilla of the Touring Cars.:)
Hi all,
Thanks
HKS 2540 Turbos
HKS Hard Piping Kit
HKS Forged Pistons
HKS Blow Off Valves
HKS Oil Cooler
720cc Injectors
Steel Crankshaft
Mines Dump Pipes
Level 3 Head Port
GTR War Link ECU
RIPS Oil Catch Can
R33 17” GTR Alloys
Braided Brake Hoses
Fire Extinguisher
RJS Racing Harness
Recaro Seats
GTR V
http://my105.com/52014
  • 3 weeks later...
There is this for sale in SA. http://www.skylinesaustralia.com/forums/sh...ead.php?t=57539
If I had the money I'd grab it but...not liquid right now. What is worth considering is that some major effort is required to improve the suspension on the older models. Right now I'm getting whupped by my mates in the GTR's on track days. At PI it is around the 10-11 seconds per lap. Consider that sticky tyres take off an extra 5 seconds, that's still 5-6 seconds I hope to make up with fixing my diff which is open wheeling and putting good suspension on, oh and maybe a few more kW.
The GTR setup is just so good straight away that I'm tempted to have one for a dedicated track car, but listen to the people who run race cars right now. There are advantages to both approaches.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
