In a GTSt it wouldn't be possible to have the awd system, because the chassis is different to GTS4's and GT-R's
Would be a better to carry the conversion out in a GTS4 (non-turbo with the awd system) :D
the purple "GT-R" Advan Racing in Syd (or was it NZ?) has was a GTS4, with full RB26 engine/gearbox transplant and fenders done to it ;)
Or you could swap the RB26 over, convert it to rwd (you can keep the gearbox, basically the same internally just the difference is the awd transfer case/diff/etc that's attached onto the GT-R box)
This is all related to the R33 btw
https://www.sau.com.au/forums/topic/57194-gts-t-awd/#findComment-1105297
does the gts4 look exactly same as our 2door gts-t or are they only 4door ?
would i have to change the diff/gearbox ect in a gts4 or its same as gtr and wont break under hight power wid a rb26 in it ?
thnx again  :cheers:
33 GTS4s look the same as a 2 door GTSt, and they also came in 4 door sedans
Another thing to remember is that since they (GTS4) are non-turbo, they will have the 4-stud hubs and GTS brakes, meaning if you want to swap an RB26 in, a brake upgrade would be needed (brake upgrades are required here in Vic if you want to swap another engine in anyway, not sure about NSW)
You might as well swap the gearbox/diff and possibly the ATTESSA system as well~
An RB26 swap into an R32 GTS4 would be heaps cheaper and far more simpler and straight forward, because the drivetrain is basically the same as the R32 GT-R's..
Nissan fact: After seeing alot of their R32 GTS4s being upgraded to RB26 making a cheaper GT-R, Nissan changed the drivetrain in the R33 GTS4's and made them non turbo :) Same thing could possibly happen to FPV with their F6 Typhoon, being very similar to the Ford MkII XR6Ts, an ECU flash from the Typhoon and a bigger intercooler fitted to a MkII XR6T would make it a Typhoon on the cheap~!
https://www.sau.com.au/forums/topic/57194-gts-t-awd/#findComment-1105732
R32 GTS-4's are Turbos and they're all TYPE-M's so they have the TYPE-M kit, brakes, steering wheel, etc. RB20DET with the GT-R 4WD. Bit heavier then the GTSt but they get the launch in a straight line, the cornering is sublime and I can pull away form WRX's in the wet.
https://www.sau.com.au/forums/topic/57194-gts-t-awd/#findComment-1113692
  • 3 years later...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
