thoughts on new sticker design (pics)
Ok, as some of you will know i have been given the task of making some SAU stickers for club members etc. i serched for (SAU LOGOS) on these forums and i came across a few ideas from other members.
I ask gary1, what he thought of the idea and we agreed i would make a few samples.
Today we got around to cutting the stickers , there are two diffrent styles. i have sent 8 of each style to gary1.
i just stuck one of each on my car and took some pics so i could get a feed back from YOU !!
Please let me know what you all think.
https://www.sau.com.au/forums/topic/57512-thoughts-on-new-sticker-design-pics/
That's some nice spamming for SAu Mr Sparkle :rant:
I'm with Mase on this one. I like the last one. The red and silver on the back panel. Can we maybe get just the url's done as well www.skylinesaustralia.com but with the SAU bit in the middle a different colour or something? Just a suggestiong. Just thinking of something like that to match the other ones.
The first two that Melv has posted if what's printed on the buckle of the lanyard that funkymonkey down south has made. Looks awesome on there. I just like the slimmer longer one. Rather than the tall skinny one?
... If that makes sense
I like those ones the way they are.. not too cluttered... and you can still read it.
like the "set" we've got now is the two side window ones and the long url one.. How does that one on the panel look if you squash it down to fit that rear glass bit?
i could do that
have a set. like two of those long ones and a www.skylinesaustralia.com or www.sau.com.au sticker on its own.
:type:
I like them all tops work dude!!! :(
Left you a voicemail on your mobile too bout the club stickers just to see where they are at (sorry for hijacking thread).
But yeah AWESOME!
EDIT: Hey can you make stickers which are see through from the inside? so you could make a massive one for the rear windscreen and stuff? Prolly cost a fortune though I'd imagine :) The ricer in me has to know :(
Wouldn't mind a mirror image one to go across top of the windscreen, and or straight one for top of the rear screen. Don't fancy putting big solid stickers on the rear quarter glass. Might cut down the rear peripheral vision too much. I liked the origional small one for that area. Like the big panel one though, maybe a dot com on the end....everyone knows to put the www in front.
If anyone feels creative I'm looking for designs to put on the white 2 door (semi sedan Strutto???)
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
