Maxx
Im going to buy one from you for my Series 1 Stagea.
I understand another Stagea owner with a Series 1 is currently using your CAI Box for a R34 Skyline, and apparently it fits all ok.
My query is: are the snorkel openings for a R34 and R33 on your CAI box the same?? ie, I have a R33 snorkel but would want to use your R34 CAI box..... is this possible??
Cheers, brendan
  • Replies 141
Maxx
Cheers, brendan
would also like an answer to the same question, for the er... same reasons. cheers.
  • 1 month later...
  • 1 month later...
im in sa - any chance of getting a template made for R32 GTS-t??? Can use my car!
Seems as though there is a lot of people interested!
Yeah I would buy one if they were made for an R32 aswell.
:happy:
  • 4 weeks later...
Hey the cai box with the clear lid looks awsome the only thing is will the box fit with the after market cooler piping. the stock snorkel had to be removed to allow the piping to fit so now i got a pod with a different cai. would still be interested in the box if if fit.
Also is there a hole in the bottom of the box to allow for my induction pipe, if not i'll cut one, just wondering.
I fitted mine to my R33 a few days ago, pretty decent looking, but it is not a straight fit to an r33. I had to chop off some bits to get it to sit low enough due to the bottom bit on the left (if standing in front of engine looking in) was hitting the stock cooler piping. not much but hey.
also one of the bolts on the lid was broken off on mine so the plexiglass or whatever it is has become loose at one corner.
It does leave a fairly decent hole under the pod where engine heated air can still get in, I think for max cooling it would need this hole sectioned off too - I might make a quick template and cut one out, looks like i could bolt it to the current screwshafts on the cai. anyone else done this?
  • 3 weeks later...
Are you still sellings these CAI boxes Maxx?
sure, but i am having my holiday at QLD (indy 300)
so send me a pm and i will reply u with all the detail once i go back to adelaide
  • 1 month later...
Hi Maxx....Do you still have any clear top CAI boxes and the Aluminium hood panel for R34 GTT ? Will be down to Adelaide next week... just wondering can i pick it up from you ? :nyaanyaa:
Hi Maxx....Do you still have any clear top CAI boxes and the Aluminium hood panel for R34 GTT ? Will be down to Adelaide next week... just wondering can i pick it up from you ? ;)
sure can :miner:
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
