i thought the rb25's were making atleast 230-240kw atw with this kind of gcg hi-flow turbo, about $2000 that i seen in another post. I maybe wrong so please correct me. Just thought it would make a bit more power than that on an rb20. thanks
Yeah, thats on the RB25, 500cc more.
unless you screw a stupid stupid amount of boost into it you might get close to 230/240rwkw.
I noticed another post your trying to build a 280rwkw RB20... good luck as its a mission with the best advice i can give of... drop 40rwkw of your peak and you'll make it a lot easier/cheaper
Thanks R31NISMOID ill think about the advice.ill still wana try for 280 - 290. but if it becomes to much of a task, price and brain-muddling wise 240 maydo. What is the rb20 gearbox rated at, what type of power could it take? It wont be thrashed as i would only use that power occasionally.Also what do you reckon about these turbo's both from turbonetics to make this power? Im after something that will spool fairly quickly and stong up top. I haver all my other parts sussed but the turbo is the main concern.
The 60-1 Performance Turbocharger
Representing the careful marriage of a unique high flow/high efficiency compressor section teamed up with a T4 turbine section the 60-1 has proven itself in every competitive motorsport application from drag racing to bonneville. Available with either the standard (4” inlet, 2.5” discharge) compressor housing or the 60-1 HI-FI ( 2 3/4” inlet, 2” discharge) compressor housing, the 60-1 will outflow any standard T04B with ease! (The 60-1 HI-FI will deliver approximately 90-95% of the flow capacity of the standard 60-1.)
OR
All T3/T4 Hybrid Turbochargers are available with the patented Ceramic Ball-Bearing option highlighted in the Ceramic Ball Bearing page. The Ceramic Ball-Bearing T3/T4 Hybrid series offers the fastest spool-up available. Coupled with extreme durability, the Ceramic Ball-Bearing concept provides unparalleled performance never before experienced by the turbocharging aftermarket. All T3/T4 Hybrid's are custom matched for specific applications. Airflow ratings from 250 HP to 500 HP are available. Contact a TURBONETICS Turbo Specialist for application assistance and availability.
The first one my mechanic told me is a ball bearing and is rated at 500hp.
Any help would be awsome. Cheers
I suggest (again)
read this thread, all 48 pages of it.
Posts by a number of users in this thread (Roy is one) will give you the turbo specs and what you need to get it to 240rwkw or there abouts.
OR
60-1 comes in both bb and plain bearing
Had mine on the dyno today. A few problems but won't go in to it as its not an RB20DET.
Besides the point.. We were talking about a nice little R32 there.
THey bolted a GT3040 up to it with a .48 turbine housing from GCG, boost control was erratic, multiple forms of boost control were tried, boost would constantly peak up then fade of peak up fade off..
It was put down to a bad match turbine housing/wheel match.
A GT28 of some sort is going on it. :D
With the GT3040 .48 it made 6psi by 4000rpm, not too bad, just a pitty it didn't perform. :huh:
Yea i think he said 1200 or $1300 for the plain bearing and 1950 for the ball bearing what do u think about it? I just wana try something a lil different than the usual 230-240kw, not saying that its bad or nething, i might end up doing it myself, I wana see what else can be done with the rb20 and give use some feedback how it goes.I just need some answers for the time being as i wish to have all the work complete within these 2months.
I have gone through all these pages but there are new things people are trying each week and wana be upto date.
thanks for any help u will bring foward. :huh:
I have to say, BD4s were pricey at times, but like anything you get what you pay for and the guys were always great. They dotn do anything by halves and dont do band aid fixes (My experiences anyway over 4-5 years of using them)
In my eyes one of the better places in Sydney...and one of the few that would work back late on a Wednesday night welding up control arms for me as i had to be at the track the next morning :huh:
In my eyes one of the better places in Sydney...and one of the few that would work back late on a Wednesday night welding up control arms for me as i had to be at the track the next morning :D
yeh Tom was working back on mine aswell, other guys looked like they wanted to go home, hahaha
i couldnt believe how detailed the HKS software was, u get what u pay for but Tom wont over charge you, he will just expect a lil more $ for alot more work.
i ended up with 211rwkw @ 1 bar, no point tunring up the boost cause it would only result in larger pressure drops..
next time ill be there with a EBC @17psi, should do 220 easy.
What turbo? I thought you were running an R33 RB25 turbo?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
