Roy as far as we know, and very confident on it.. the internals of the motor are as stock as they come, no cams, cam gears nouthing
it appears to be running the stock head gasket and the sump and oil pump dont show any signs of removal befor, we will be doing a comp test this weekend.
its very basic to an extent, trust td-06 with the 16c rear, EMS stinger ecu, 34 gtr injectors, tial 38mm gate, profec b spec II on 24psi high 20 low, 76mm china cooler kit then usual exhaust-intake stuff
if the weather holds up for next wednesday im goin to return the car back to the drag setup and try and get a run in at the last street meet for the season, it feels like its a shit load faster now then when it was last on the track :)
im sorry but.. is there any outher 12.0 or lower unopened rb20 r32 in australia??
martini race fuel http://www.martiniracing.com.au/html/fuels110.htm thats what i'll be using if i choose to (at this moment i see pump fuel is a greater acheivement)
Sure is, my mates 32 which i sold on here a couple of years ago, ran a 11.8 @ 116mph. ON that run it popped the motor at 3/4 track but stayed into it.
That was stock motor, manifold, injectors & ecu (had a chip though). Was laggy as f**k but it ripped.
h.
h.
mint atleast i know what to aim for next week :P
conversion coming along slowly
i need some panel n paint done first
and a diff
finding a diff for a hr31 isn't easy!
then i can start collecting the cool stuff for conversion:)
i have front cut already though
What is wrong with the current diff in it?
R200 long noses are a mechanical 1 way diff from factory.
If its a single spinner get an LSD centre off a Z or similar and put your gearing in it...some new clutch packs and voila.....
That is what I am doing. Minus the LSD as I already have one.
If ya wanna know more speak to R31 Nizmoid or look at the array of info on the R31 club
hks 2835 is a nice turbo!
my mates s13 which i'm using atm has one on his sr
and i'm pretty sure the dude with the rb20 120y has done 11s adam and don't think he's opened the motor yet
i cant be bothered going for a look haha
I am running 20 thou low comp forgies... Top end is std tho :/ 11.0 @ 118
Juat reading through some of the first few pages of this thread. Around 30 months later its interesting to see how the goal posts have moved and thinking changed. 220rwkws with a GCG Hi Flow was thought to be about it for an RB20. We are now getting better response and more power out of them just by experimenting a little with setups.
If you could get the air in to the RB20DET with reasonable boost I think the RB20DET will hold 450hp no problems.
AD4M, lol 24psi is more then what i would call reasonable. But hey, its hanging together. Fingres crossed you pull some great times and it holds together.
Can i ask whether you think it will hold together at that boost? Or is it a matter of you not caring if she goes bang :/
Compressor:
- Wheel: 82mm w/ 56 trim
- Housing: .70 ar
- Type housing w/ 4" Inlet & 2.5" Outlet
This turbo incorporates the same GT40 compressor wheel found in the popular GT35, but runs the smaller 60mm w/84 trim turbine wheel from the GT30R. Appropriate for smaller engines where the GT35/40R feels too big, but the high amount of compressor flow is needed for the desired HP. Comes with a large T04S style compressor housing with 4.00 inlet and 2.50" outlet
These are the only spec's I could find on it
Cheers Peter
Whoops still logged on as daughterinlaw
if the weather holds up for next wednesday im goin to return the car back to the drag setup and try and get a run in at the last street meet for the season, it feels like its a shit load faster now then when it was last on the track :unsure:
Ill be watching this space closely !
Good Luck dude !!
QUOTE(RNS-11Z @ 24 May 2007, 02:00 PM)
whats next... stock turbo? According to ur statement above it would have done an 11.3 if it hadnt blown 3/4 down the track.
Are we still talkin about a RB20?
Stock everything = 500HP LOLOL
Edited by jnr32r
i know all of the above but thanks anyway dude:)
car has been off the road for a while and i sold the factory lsd to a mate with plans of getting a aftermarket 2 way for it and i've been a member of the r31 club for a couple years now:)
thanks
Can i ask whether you think it will hold together at that boost? Or is it a matter of you not caring if she goes bang :)
to tell you the truth Roy I'm not worried if it goes bang, got a few spares :unsure: the motor was running insanley rich but now its back into a more leaner tune so time will tell how it holds up
Yeh fair enough. I understand completely as im in the same boat. Happy to run 1.3bar with the occasional hits of 1.5bar as RB20s are so cheap and i have something better in the wings. But in no huury to throw in a stronger motor because at the moment the engine is faster then the suspension at the moment. So can go quicker yet once i get the suspension sorted. Something very satisfying about pulling away from built RB25s etc down the straights at the track :unsure:
Something very satisfying about pulling away from built RB25s etc down the straights at the track smile.gif
Haha this awesome feeling is what keeps u guys from going to rb25 or something :unsure: LOL
Edited by robots
roy mate i will be using the gt30r, the one with those specs which is the same core specs as the hks3037s
should be starting it tomorrow, need to tune it roughly and drivable, then off to JEM for the fine tune
i have:
autronic ecu 550cc rx7 series 5 injectors 044 pump CPC plenum port polished head/manifold 1mm oversized valves hks valve springs gt30r 38mm tial wastegate
hopefully i should get around the 240-260rwkw mark
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
