Just a thought, why not hold it at someplace like the Laurel Hill Convention Centre, between Batlow and Tumbarumba.  Accommodation, food, and maybe drinks [not sure] if not then byo.  Showers, toilets etc and I reckon price would be low-ish.
There are other centre's around like that one, they make good bases for car/motorcycle meets etc.
Anyway January in Wagga doesn't sound too flash, +40'C days and all [good drinking weather though].
As written...........
  • Replies 252
Stay tuned wises, Kamikaze and I are trying to get something happening.
We reckon a day meet to meet everyone and then set a date, place and time for a Murray-Murrumbidgee Skyline Day.
We'll keep everyone posted here, if you know of other skyline owners, let them know. R3? whatever as long as it's a skyline.
I'll just ghost this post Tri. Let me know if you need me to encourage the locals. Pretty certain tho that you can rev em up mate.
R
Hey guys,
Just found this post....
Laurel Hill is a great venue (I had a relative that used to mange the place). I'm not sure of pricing but will try to find out today. Wagga will be mid 40's during January, but if we based ourselves in the mountains you can expect it would be somewhat cooler... after all, Laurel Hill is 1500 metres higher than Wagga.
I think we should all head over to Fatz track day, I'm going and think it would be great to get some country cars out there.
The Nat's weekend in Canberra is another good option, or just a cruise there at some stage. I head over there heaps to cruise and enjoy some good roads.. I'll let you ACT guys know next time I'm over there..
Narrandra drags will be hot as, but I'd still go...
So yeah, get a general consensus - but I'd have to say either Canberra for the roads, or Larel Hill for some mountain coolness :D
I'd say Canberra has less ummm.. hassels. in a blue way....
Sorry oscar, thought you knew this thread, actually thought it was you that told me about it, how wrong can a fella be.........
We were just trying to organise a meeting to get everyone together so we can plan some things like a 'Skyline Day' [that may turn into a weekend] that would be worthwhile for ppl from Canberra etc to attend. They may not come to some sh1tty little meeting [and who would blame them], but they might come to a party meeting.
I was thinking Laurel Hill cos we would all be together, we could organise food, drinks, a band/DJ, and do it all for a under say [don't really know yet] $50 a head, but this is the sort of thing we need to talk about, so first step is to have a meeting somewhere to meet and talk with Albury/Griffith/Wagga etc etc.
Stay tuned..............
Well, I'm thinking that the date for the meeting will be either 23rd January, or 6th February 2005.
It's later than we all were thinking, but..............Simmernats 6th/7th January, Fatz track day 15th/16th January, 23rd is free, then 30th will be Australia Day type weekend [26th January].
I'm thinking that the 6th Februaury might be best, gives everyone time to plan etc.
Please post if you think otherwise.
Jeez ya wanna know everything doncha.............
Don't know yet, I'll arrange something, but probably make it in Wagga, it's most central to Albury, Tumut, Griffith, Leeton, Cootamundra, Young etc
Any suggestions, we could maybe get the back room of the Shanty hotel at Alfredtown near Wagga??? {I could see Mick and ask}. If you have a better idea let me know.
Trying to avoid anyones house at this point, I feel [and I don't know why] it's probably best for now.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
