rural 'liners
wises
 Share
Your garage got room for 20 or so liners.
Drivers have a huge thirst and so do our rides. Can you get BP Ultimate down that way and Boost.
Youve been a nauti girl babe - spankings are too good for you...lmao C U on Sunday
  • Replies 252
yeah sin of course u can get bp98 down here... its not zimbabwe :cheers:
stolly - i used to live in deniliquin, i think ive met over half the population of aerials on this planet :)
cassi - most of us have the winton fun day on sunday so i dont think many will come from here.... wagga maybe
- Yeah you can get BP Ultimate here, God damn boy we've even got running water and toilets that flush now. Got a shit load of room, big secure yard
I thought that'd get some comments...:( good to see country cousins...LoL. Running water, BPU and electrickry. Great pubs and good times to be had then.
Spent the last 18 months down Albury way at a little town Corowa. Worked at the Toby's Factory at Wahgunya. You might have seen my Black GTS-T (same plates).
Got smoked by a guy in a white 180sx from Wodonga :Oops: . Mind you it was quick and having missed second it was all over. Had to move back to Canberra, so embarrasing. Now I got me a GTR and looking to hand his ass back to him on a plate next year.
R
..Corowa's not a bad little town, I'm sure there would have been heaps of skylines there!! Have a good time tomorrow on the cruise, sounds like a good group, I would have liked to have gone over for a run but have two Xmas parties that can't get out of, anyway - next time
Just a thought, why not hold it at someplace like the Laurel Hill Convention Centre, between Batlow and Tumbarumba. Accommodation, food, and maybe drinks [not sure] if not then byo. Showers, toilets etc and I reckon price would be low-ish.
There are other centre's around like that one, they make good bases for car/motorcycle meets etc.
Anyway January in Wagga doesn't sound too flash, +40'C days and all [good drinking weather though].
True - High temp is a pain, latter in the year is good.
BTW
The ACTSAU Chrissy Cruise was great guys (Big Day Out!). Sorry none of you could make it here.
Trident came down from the mountains with a mate both in liners. (he really is a bikie in a Skyline). Local Canberra lads showed up in numbers.
Cruising out there in a pack of R32 GTR's and a 33 with GSXR 1000 riding shotgun was just an AWSOME sight. Pulled up to find a whole heap more liners (31,32,33 + 34's) lining the picnic area.
After the BBQ cruised back to the Jerra Pub and party'd hard till stumps.
Really impressed with the responsible attitude shown by all.
 Share
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
    • Yes that sounds right. Cars currently in the shop for the engine work. Will need to remeasure .. but yes I think I must be targeting 45cm from fender.
