im in cairns and it's never happend to me it gets blody hot here
Yeah mate, figured no-one else had this problem... Its f#$&^d!!!
Just hoping that someone knew wat was going on - considering this is a Skyline website and ppl CLAIM to know wat they are talking about!!
Thanx anyway.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1126940
Your car is fu(ked, :P
Yeah thanks for that... Just in case i didnt know!!!
Besides the blatently obvious of it being a pain in the ass, the fact that ppl look at Skylines and it stalls just about anywhere makes it a bitch to go anywhere without having every1 laugh at ya!!! Fun and games hey??
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127305
this problem was happening with my soarer, and I realised that it was my amp power wire had got melted over the back seat, and was shorting out.
I guess try to look at all obvious things - check wiring, batt terminals etc
Yeah had thought of that but when it turns off the electrics stay on so it wouldn't be a short...
Had about 1001 ideas of wat it could be but so far nothing, revs used 2 be unstable 2, changing between 300 - 2100 all the time, so i thought the turning off could have been related but found that the idle problem was just an average attempt to re-connect the RPM wire!!!
Thanks for your suggestion anyway.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127320
Sorry guys - probably 2 vague, but was pretty sceptical from the start...
Alright this is what we're talking about:-
It has turned off while cruising or idiling - these 2 are the most common.
But it also has occasionally turned off on takeoff, or breaking hard!
The only time it NEVER turns off is when i'm really giving it to it.
It also seems to flat spot (if that's what you'd call it) i'll be driving along and it just stops responding for maybe 1 or 2 seconds, no matter how far the accelerator is down it does nothing, then it will kick back and keep going - it almost seems like it is trying to turn off... If it does this a couple of times, all i have to do is put it in Neutral while driving along and the revs drop to 0 and she turns off.
Electrics stay on though so i've ruled out a short, it also starts up straight away 2.
Another thing that it does is if I'm driving on a warmish - hot day, the flat spotting will occur and if i can manage to keep it on, the next time i go to drive it (no matter how long it is after it) it plays up, almost like its got a memory (thats where i was thinking the ECU)
It's very common during the warmer weather, almost unheard of during the colder - and its pretty much got me fu$&@d...
That's about it...
Hope this helps, if u need anymore info let me know...
Thanks all!!
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127534
it sounds like something i read on the forum about the fuel pump earth or sumthing shorting out.. finding the earth and reconnect it in a better location.. worth a shot. also check that your spark plugs are screwd in nice and tight.. disconnect and connect your battery after you try it.. hope this helps.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127544
I'm no expert, but have you checked for leaks along the intake system? If unmetered air is getting into the system after the AFM, then that could make it run shit. A celica I owned had a crack in the intake plumbing and the bastard would not idle, almost dying all the time and bunny-hopped on take off.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127554
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
