  • Replies 40
I got a digitla video camera, a printer/scanner for digi photos.. some clothes..umm...watch, simpsons clock..and little assorted goodies ;)
gotta love it.. jesus dies we get chocolate..hes born we get presents ..:D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
