when i got my cooler fitted with my pod, my stock bov was fluttering, now i have the GFB Hybrid bov and its great, no problems with stalling due to part atmo/part plumback, just as loud as supersonic bov, and it flutters when i make about 3psi max then its just like normal over that so it shouldnt cause much damage on the turbo...
ben...
  • Replies 41
Anything under  6psi will not harm your turbo....
A HR31 does not even have a BOV as standard (i used to own a couple)
If you plan on running 7+ psi then use the above info...
Col... HR31 and VLt's didnt have BOVs... but then again they are 80's technoology cars and these days almost all turbo cars have factory fitted bovs
  • 4 weeks later...
that noise you all want is damaging your turbo i know it sounds good i have it myself and yes by blocking off the blow of valve you will get this noise thats how i get it also using a pod filter the noise is caused when the throttle body is shut the air in the pipes has nowhere else to go but back normally out the blow off valve but since its been blocked it can only go out through the front housing of the turbo wich causes the turbo to try turning back the other way producing alot of stress on the shaft it bounces back and forth of between the throttle body and front housing till all the air has escapped so NOT GOOD but sounds great i have yet to blow up a turbo but mine is aftermarket just thought you might like to know a few things i own my own shop and often mod cars and people ask for this sound and i wont do it for obvious reasons WHEN IT BLOWS UP I PAY
  • 4 months later...
most of the drifters here in okinawa have this sound....its called backpressure. my car has it, what i did was take the hr31 piping and put this where the blowoff piping was, then hooked up my boost gauge to the vacuum line and plugged the bigger hose with a bottle cap. it wont damage your turbine if you have the stock turbine and intercooler...it should be fine
BAD BAD BAD. Don't do it. I blew a turbo from not having a BOV fitted running only 11psi. Get a steel shaft turbo if you want that noise.
The turbo is flowing a LOT of air under boost and as soon as you release throttle the throttbe body closes while the turbo is still spinning causing it to reach very high boost levels between the turbo and throttle body.
If you want to see for yourself how bad it is just hook your boost gauge up before the throttle body and watch the needle go off the scale when you take your foot off the gas.
ben...
Nengun sell a HKS product that prevents atmosphere style BOV from stalling the car. However i had no problems with a GFB mach 1 atmospheric type on my r34.
http://www.nengun.com/catalogue/product/578
Edited by RyanN
It is not proven that not running a bov will harm the turbo at all even at high PSI.
It can even cause the car the be less responsive as you have to repressurize all the tubing when you get back on the throttle. (More noticeble with a frontmount)
  • 3 months later...
The fluttering effect that ppl get is compressor surge which is the air building up when the butterfly flap is closed (not accellerating) and pushing back to the turbo bouncing the returning air off the fins.
I wouldnt recommend it as if you are running a ceramic turbo this stuter effect that is being forced on the turbo can break off the ceramic blades, which will result in one screwed up turbo.... Sounds cool, but messes sum turbos up bad..
  • 2 months later...
gheyest thread ever. omg fullsick hektik I get to make a flutter noise.
Backpressure is harmful especially if you're running non standard boost levels. However, its all fun and games on stock systems. Hell my 57 year old dad's Cefiro came with factory flutter because they have no BOV in stock form so the backpressure makes the RB20DET turbo "flutter".
In any case, how in the hell did this become a DIY thread. Moved.
lol! How indeed! I guess it does tell you how to do it... blocking off your BOV.
Sounds like we need a new section for "decreasing performance". It can contain large chrome wheels, blocking off BOV's, and buying Chinese eBay manifolds! =-p
I guess the people with knowledge on this decided that telling the same thing over and over and over and over and over and possibly much more over again, is too much and don't bother when new posts liek this come up.
here is a VERY good explanation of it all.
sure it's on NS.com but the author is a very knowledgeable person..
http://www.nissansilvia.com/forums/index.p...=28060&hl=stock
read it and then shut the hell up about flutter and what your theory on it all is.
if a mod wants to make that link above a sticky about fluttering, then that would be good.
then if the mods would BAN FOR LIFE any person that mentions flutter again, that will also be good
F#CKEN AYE!!! I don't even bother explaining it anymore when people ask about why my car makes certain noises. Just pat them on the head and say "Just keep doing your thing guy"
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
