My trip to Tokyo, Japan!! - not 56K friendly...
  • Replies 48
Awesome pics there. That Mount Fuji one at the end could easily be in a brochure, it is that good.
That three wheeler is British registered from the late 60's if I can read the bottom row of the plate correctly. Never seen one before in my life though!
Great pics though man
Sakai's food tasty :)
Some more pics...
Some quality Japlish:
Stag in Hakone:
Chinatown in Yokohama - biggest Chinatown in Japan:
nice R34 in front of g/f's house
Yokohama port shops
temples
big buddha (not nearly as big as the one in Hong Kong!... now that's BIG):
Yokohama
maybe i should change my team from tofu to 'cream soda'?!?:
Kiddy Land - 6 levels of toys!
some arts building or something in Tokyo Bay
Super Autobacs Tokyo Bay
nice Toyota wagon
Junk Jewel?!?
Mos burger mmm
Shibuya:
Building that looks like a boat in Tokyo Bay - maritime museum
Meiju shrine:
one of many vending machines
oh, and I did bring some goodies home...
Nismo filter, Nismo oil cap, Apexi EVCR, Apexi VAFC (for a mate's civic - second hand from Up Garage :) )
Tomei Poncams IN/EX 260 degree, 9.15 lift
Defi black face boost 60mm, oil temp, water temp, oil pressure (52mm) and controller second hand from Up Garage
:D:)
Gauges with all sensors, looms etc cost approx $600 bucks second hand.
For reference, the VAFC for Vtec was $280...
second hand stuff is plentyful and you can save heaps!
Also, the stuff from 'Up Garage' is very very good condition :)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
