I just finished installing my new head unit and amp into the stagea. took me a while but i don't have any wires showing what so ever. it's really a rather simple job, you just have to be prepared to pull most of your interior trim out to hide the wires, same as you would in any car. i ran the power cable for the Amp down the inside of the front right quarter panel straight to the battery, and it goes all the way back to the amp, which at the moment is just sitting in the boot. i'm rigging up a custom sub box in the next few weeks, which i will take photo's of during the install.
My plans are to have 2 x 10" or 12" subs plus the amp sitting in a box which deosn't look outrageous, but does the job. will keep every one informed if anyone wants/needs to know anything about stereo installs
https://www.sau.com.au/forums/topic/60975-more-stereo-installation/
  • Replies 46
Sounds good Term. You could easily fit two 12's in a ported box behind the seat. Make it removable so you can pull it out when you need to etc.
Where abouts are you gunna mount the amp ? I've got a MT 280 that'll fit nicely in the spare tyre well. I just need to get some power cable/fuse and a long set of RCA's.
J
I have a large V12 alpine amp, it's fairly big, about 400mm long. i don't want to lose my spare tyre, so i'll be mounting it either inside or on top of the sub box. i measured up the back end, and i think i've got it sorted out to the size of the box required.
I think so. it's simple enough, just pop the vents out, then pop the center console out. center console removes easier if you take the center pocket out and push underneath it. then it's just as simlpe as unscrewing the headunit and replacing.
I have a gap in mine at the moment, i'm waiting to try and find a set of 3 guages that i can fit in there, otherwise i'll have to make my own
Yepp, it's pretty straight forward. It's just the top two vents are a bit of a bugga to get out. You can take the hazard light switch out (just pops out easy) and push from the back of the vents.
I found out the other day I've got no speakers in the back doors :P One day I'll get new 2 or 3 ways all round.
Term - damn that's a big amp !! The little MTX 280 I've got is a 2 channel jobbie for just the small sub I've got. It'll fit nicely in the middle of the spare wheel, so i can leave the spare in there and the amp will fit in the middle of it :rant:
I haven't measured it up yet but I am hoping to put one of these in the spare (Din) space
If it does't quite fit it won't matter, I don't use the ashtray, so it can go down there.:P
i tell you what guys, making up a custom sub box that fits nicely in the boot of the stagea is a fun job. an entire day of jig sawing and i'm almost there. just gotta trim some bits, glue/nail it together and then find carpet to match the interior and it'll be all done.
I suppose i should take down measurements for you guys in case you ever decide to make one. shouldn't be too hard to modify mine, it's nothing special.
Anywho, off to Tempe tomorrow for some nice new wheels. sub box will have to wait until friday to be finished. i'll get pics up soon.
Sounds like everythings comign along good for you terminal, be good to see what it looks like with some new wheels, what size are you planning on?
One problem I have found with the stagea over the past days is tooo much space, have to work out a way to have items stay in one spot and still have some fun in the car..
I have one of those big plastic storage boxes (Bunnings ~$10) tied down with occy straps for small things, just chuck them in. I have spare occys (pack of 10 from SupaCrap ~$6) for large stuff:cheers:
Haha thats a great idea, definatly heading there this weekend to buy me some :)
Also make sure the tyres load rating is correct that they give you at Tempe, from memory you need at least 570kg loading capacity on each tyre, check in your glovebox in its in there in the paragraph below the table (sorry dont have the car handy at the moment)
i am building a removable box for my amps and sub with switches so i can switch the speakers to run from the H/U when the amps are out.... pretty big job, but should be good when its done.
Yup the load rating is the one you are after, it should be a figure over 500kg..
I know for a fact police/transport check that your tyres are correct for the car, the max load rating is stamped on all tyres and must be higher/equal to then that specified on the car.
Thats one of the reasons the guys in the luxs etc. have problems because they have quite a high rating from memory due to the ability of taking a large load in the rear tray.
Just make sure they give you the proper load rating :)
This is almost the exact same thing i'm doing with mine. great minds think alike
It says on mine must be over 600kg on each corner. has cold inflation pressure and 2 sizes of tyres that the stock rims came with, 205 and 225.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
