Attention: Vending Machine In Chiba Stole My Yen
^^^^ Red alert, Red alert... Japan fever has set in and causing random posting on totally ghey occurances... Red alert
Hehehe hope your having a good time maaaaaaaate! :)
haha went to nagoya today
u should go to nagoyako (nagoya port)
they have the maddest aquarium
supposedly the biggest in japan
2000 yen to get in but its well worth it
and the scenery of the port is great
Geez you get around don't ya???
Get around my ass, beenon train for 12 hours, this is the second day I have been on a train for 12 hours. Went to sapporo to pack the container. -12 to -5. Damn cold. I am in Ueno tonight and will be in Chiba tommorow at midday.
Cheers,
Ken
true.
Richard tried to by a 40 of beer and the punk bitch stole his yen. word.
Man, thats just wrong, I know its cold but beer is a very important part of every breakfast.
Lol... kinda like on my first day in japan, the vending machine stole my yen too... and I so wanted that cafe au latte... What makes it worse is, I went back the second day because I thought it should have been fixed............... and again!!!
im in chiba at the moment. just got over my london jetlag.. everything is so confusing here. at the moment ive got no idea where i am, i walked for ages then walked up a flight of stairs and found a MANBOO!! - i think thats there name for an internet cafe?
anyway time to continue walking till i find my hotel again.
by the way.. the tv sucks its all in japanese, and the porn is rather freaky!!
Well, right now a bunch of us, RBNT included are drinking it up here in the penthouse at the New Tsukamoto.
And no further joy with the vending machine revenge, that bastard machine will have its day yet!
firstly sorry for the random post (it was me accidentally post as Nick). :oops:
thanks for all your support, all I will say is that punk vending machine will think twice before coming between me and my beer again. we must stand united against these theifing machines or soon this kind of thing will be come wide spread.
Richard
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
